Lighting HID/Xenon kits, Retrofits and Associated Topics
HID bulb wire
Old Oct 21, 2007 | 09:17 PM
dc2acgsr99's Avatar
Default HID bulb wire
I have a 99 Integra and received a HID kit a while back, on the wire that goes from the bulb to the ballast there was a piece of rubber going around it that the wires went through. I attempted to cut it and managed to cut the wires on the one bulb, rushing never got me anywhere faster. Anyways I went to hook it up anyways by twisting the wires together and the light turns on fine but after a good 15 seconds of light it flickers and goes out, turn the lights off and back on it does the same. Also I have switched ballasts and it yielded the same results on the other side. Now I am trying not to buy another bulb so would anyone think that if I soldered the wires together that the problem would be resolved or am I going to have to get a new bulb?
Old Oct 21, 2007 | 09:55 PM
fongyz22's Avatar
Default Re: HID bulb wire (dc2acgsr99)
you're sentences seem to have run-on and fragments... re-word and possibly post a diagram of what your setup is like?? would really help out.....
Old Oct 21, 2007 | 10:37 PM
dc2acgsr99's Avatar
My question more specifically... If the wires happen to get cut on a HID bulb could it be repaired and reused or should it be replaced?
Thanks for the note on the grammar? Completely off subject...
Old Oct 22, 2007 | 10:11 AM
fongyz22's Avatar
if you're using an HID PNP kit, then there should a positive (usually red) and negative ( black) wire; if any of these are cut, just re-wire then back to the two wires that connect to the ballasts / ignitors. they should still work this way as long as you have not touched the actual bulbs in any way.
Old Oct 22, 2007 | 03:19 PM
dc2acgsr99's Avatar
Alright thanks for the feedback I appreciate it.
my00civic
Lighting
Feb 24, 2011 08:25 AM
gringotegra
Lighting
Jan 9, 2010 07:09 PM
exsuntechnology
Lighting
Nov 29, 2007 04:51 PM
TypRice
Nov 14, 2002 04:24 PM
