sc61 oil pressure
Old Oct 21, 2007 | 08:24 PM
powerdbygarrett's Avatar
Default sc61 oil pressure
with my new build on the first start up my oil pressure to the turbo was at 80psi after the restrictor? is that to much? should i get a new restrictor? or is my gauge screwed up? its an autometer mechanical gauge. thanks
Modified by powerdbygarrett at 11:00 PM 10/21/2007
Old Oct 21, 2007 | 08:31 PM
qfast817's Avatar
Default Re: sc61 oil pressure (powerdbygarrett)
how long did you wait after start up? my gauge reads 80psi till it warms up then it drops to 30psi
Old Dec 12, 2007 | 09:12 AM
Tjabo's Avatar
Default Re: sc61 oil pressure (qfast817)
Do SC61s generally like a restrictor, or not?
Thanks!
Old Dec 12, 2007 | 09:26 AM
supergenius's Avatar
Default Re: sc61 oil pressure (Tjabo)
-3 no restricor here... 80 when cold, 15 when warm at idle.
No problems at all
Old Dec 12, 2007 | 09:40 AM
Tjabo's Avatar
Default Re: sc61 oil pressure (supergenius)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by supergenius &raquo;</TD></TR><TR><TD CLASS="quote">-3 no restricor here... 80 when cold, 15 when warm at idle.
No problems at all</TD></TR></TABLE>
Excellent, thanks!
Hey, while I've got you, how about a couple of follow-up questions?:
1) Is that oil feed hole on the SC61 a 1/8" NPT hole?
2) All of the 1 foot long oil feed lines I see are -4. Where is a good place to get a -3 line?
Thanks again!
Old Dec 12, 2007 | 10:00 AM
vietjdmboi's Avatar
PM Flamenco-T..he will have what you need.
Old Dec 12, 2007 | 10:45 AM
Tjabo's Avatar
Default Re: (vietjdmboi)
Okay, thanks!
Old Dec 12, 2007 | 11:48 AM
akira712's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan &raquo;</TD></TR><TR><TD CLASS="quote">I'll answer specifically to your question on the SC61. I just don't have the time anymore to go through a whole symposium like I used to. In your case, If this is indeed a Honda block that you're running, NO an oil restrictor is not necessary for a -3AN line that comes from the oil sender to the turbo itself. the pressure at the line would be about 30psi or so consistently. It will be a different pressure reading at the block itself, then at the end of the feed line. I believe that the SC61 with the p-trim wheel (6169?) uses a 1/4NPT fitting, so you should be pretty good.</TD></TR></TABLE>
What TheShodan has to say about using restrictors with an sc61, id take his word
Old Dec 12, 2007 | 12:24 PM
Default Re: sc61 oil pressure (akira712)
except that the feed fitting is 1/8 NPT, Not 1/4.
Old Dec 13, 2007 | 09:30 AM
akira712's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by supergenius &raquo;</TD></TR><TR><TD CLASS="quote">except that the feed fitting is 1/8 NPT, Not 1/4.</TD></TR></TABLE>
Yes he was saying for the SC6169, mine also has the 1/8npt, SC6152SP
laziebun
Apr 24, 2008 11:36 AM
soontobeboost
Jan 6, 2007 06:22 AM
TurbodTegSfaria
Oct 6, 2006 10:35 AM
TurboCX
Aug 3, 2003 06:33 PM
DuNkiN
Feb 22, 2002 05:50 AM
