rattleing sound at 3000 rpm... help!!!
Old Oct 21, 2007 | 01:51 AM
krayz3e's Avatar
Default rattleing sound at 3000 rpm... help!!!
whenever i drive my car and it hits 3000 rpm, i here this rattleing sound. After i pass 4000, it stops. Someone help?
Old Oct 21, 2007 | 06:39 AM
slammedNslowLS's Avatar
it would hard as **** for someone to hop no here you and tell you without knowing where its coming from and actually hearing it. it could be many things
Old Oct 21, 2007 | 07:53 AM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
Default Re: (slammedNslowLS)
could be your cat rattling... heat shield...
Old Oct 21, 2007 | 07:58 AM
team714's Avatar
Default Re: rattleing sound at 3000 rpm... help!!! (krayz3e)
had the same problem. i changed my stock header to a dc header. problem with away. a lot of people say its the heat shield or a gasket inside the header collector.
Old Oct 21, 2007 | 08:00 AM
Dogginator's Avatar
Daisy... Daisy...
Get a friend and have them reproduce the sound while revving in neutral. Search for it. Most likely it is a heat shield on the exhaust. You can also use the hammer method, where you tap on the exhaust to reproduce any rattles.
Old Oct 21, 2007 | 08:52 AM
intgraCA's Avatar
Default Re: rattleing sound at 3000 rpm... help!!! (Dogginator)
first time i had it was fixed after i removed the heat shield. i had it again recently and i had a blown cat.
Old Oct 21, 2007 | 10:09 AM
krayz3e's Avatar
hmm.... my headers are really old and rusty...maybe its cause of that? I have no heat shield.. so yeahh. thanks for the help.
Old Oct 21, 2007 | 01:28 PM
TightEyez's Avatar
just wondering how many heat shields are there in a dc2? I got that rattle too but only when Im driving, and its not coming from the heat shield thats on the header. So Im guessing I only have the heatshield on the cat that needs to be checked? can someone please verify
Old Oct 21, 2007 | 01:42 PM
HGZ's Avatar
HGZ
Default Re: rattleing sound at 3000 rpm... help!!! (TightEyez)
i used to have a rattle a few years ago and it was definitely the heat shield on the exhaust, so i took it off.
then earlier this year i replaced the cat and about 4 months later i started hearing a rattle again and it turned out to be one of the welds that had come apart on the heat shield of the cat. so i ripped that shield off the cat and got rid of the rattle.
hope this helps.
Old Oct 21, 2007 | 02:16 PM
Marc3's Avatar
Default Re: rattleing sound at 3000 rpm... help!!! (HGZ)
Sorry for a little bit of a thread jack but is there really a difference in underhood temps with the heat shield removed? I get this rattle too and Im 90% positive its the heat shield.
Old Oct 21, 2007 | 05:33 PM
krayz3e's Avatar
thanks for the help everyone!
Old Oct 21, 2007 | 05:49 PM
beastman@'s Avatar
There are heat shields on your header (stock), cat, and above the exhaust pretty much all the way back.
I have the rattle too, from 2700-2800rpm. I've been ******* with all of my heat shields and haven't got rid of it yet.
Old Oct 21, 2007 | 05:55 PM
94 IntegraLS's Avatar
Default Re: (beastman@)
I had a rattle at 3k RPM's also... found out what it was when I swapped out my ca back... the heat shield on the cat rotted out at the bolts so the cover would rattle at idle and at about 3k RPMS.
Old Oct 21, 2007 | 11:13 PM
krayz3e's Avatar
what should i do? get a new cat back? cause i have stocks.
Old Oct 22, 2007 | 04:48 AM
Mfoehrkolb's Avatar
i had a couple rattles on my car, 1 was a lose bolt on my header where it connects 4 - 2. the other was my heat shield. and if its not that, you can check your rubber boots that hang your exhuast.
Old Oct 22, 2007 | 05:56 AM
beastman@'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krayz3e &raquo;</TD></TR><TR><TD CLASS="quote">what should i do? get a new cat back? cause i have stocks.</TD></TR></TABLE>
A new cat-back is a good upgrade over stock, and chances are you'll eliminate the rattle by installing a new cat back and a new cat/test pipe.
Old Oct 22, 2007 | 07:25 AM
95integraLS003's Avatar
Default Re: rattleing sound at 3000 rpm... help!!! (beastman@)
I had this problem and it ended up being a metal plate under the dash that a screw was missing on it. i put one in and that was one problem, now i get a very very mild viberation from the shifter.. grr
Old Oct 22, 2007 | 09:55 AM
krayz3e's Avatar
all try all the stuff you guys listed... thanks for the help!
madriagax619
Mar 22, 2009 12:42 PM
vietnogi
Sep 24, 2005 11:45 AM
RS_91
Mar 25, 2003 08:21 AM
Toda Built
Feb 1, 2003 08:22 AM
oryanh
Aug 30, 2002 01:15 PM
