Hard to start in the mornings....
Old Oct 20, 2007 | 06:20 PM
nemesis25's Avatar
Default Hard to start in the mornings....
Thanks for looking. I have a 92 si, which recenlty is having hard starts. This seems to be happening when it's cold (usually in the morning). By hard starts I mean, I have to hold the key longer than usual in the starting position or use two attempts for it to start. However, it does start and run fine but the first start is buggin the **** out of me. Tried search but to no avail.
So, if anyone has any input don't hesitate.
Thanks.
Old Oct 20, 2007 | 06:56 PM
Acidcrakker's Avatar
Default Re: Hard to start in the mornings.... (nemesis25)
Heres a shot to the moon.
Main Relay, although it usally happens when its hot. I just did mine on my 92 si. It would crank but not over. Let it sit for a min and it would start fine.
Old Oct 20, 2007 | 07:48 PM
dagle's Avatar
Default Re: Hard to start in the mornings.... (Acidcrakker)
how old's your battery and how many cold cranking amps is it rated at? get one of your friends' battery w/ higher CCA and fire her up.. if it responds better.. well then u know ur battery's not beefy enough.
Old Oct 20, 2007 | 08:30 PM
snobordboy's Avatar
Moderator
yeah the battery is your issue I would assume, get one with more CCA, or just a new one, Optima, Interstate are good brands.
Old Oct 20, 2007 | 09:49 PM
prelude_93vtec's Avatar
ya i had the same problem with my car in the winter and it was just a weak batery. what i would do is get another car in the morning and try jumping your car. if it starts easy, then its the battery. if it stil has troubles, i'd check the relay but im pretty sure its the battery
Old Oct 20, 2007 | 10:01 PM
Duane_in_Japan's Avatar
https://honda-tech.com/zerothread?id=2120216
Do some research my friend, this thread is fairly new. There is plenty to find.
Old Oct 21, 2007 | 10:47 AM
saikou's Avatar
I had this same problem in the mornings and it would disappear later on during the day when it warms up. I changed my fuel pump out (not for this reason) and it got rid of the cold start issues. Starts on the first try, every try.
Old Oct 21, 2007 | 04:43 PM
Giant_Bean's Avatar
Default Re: (saikou)
When was the last time you did a tune-up? Plugs, wires, cap/rotor, fuel filter etc. Had a similar problem with my old car, and that took care of it.
reithegreat
Jul 2, 2009 11:20 AM
roxics
Jan 6, 2007 10:18 PM
Bloopsta
Dec 5, 2006 10:26 PM
jimmyxthai
Aug 3, 2005 05:37 PM
scrap1ngsr
Dec 10, 2003 06:10 PM
