Wheel Bearings?...or something else??
Old Oct 20, 2007 | 01:02 PM
Honduh Uhcord's Avatar
Default Wheel Bearings?...or something else??
My rear driver side tire is wobbly...i went into a corner kinda hard and pulled the E-brake and ever since then its been a little wobbly...i dont know if i messed up my bearing (my brother suggested my rim might be bent) or maybe some suspension issues? im not sure...any ideas?? I checked the owners manual on this problem and Haynes said it could be a bearing...i searched the FAQ here and did the search and returned no results although im sure theres some post but this seems pretty specific...thanks
by the way its a 94 LX...
Old Oct 20, 2007 | 01:18 PM
NeKe1point0's Avatar
Default Re: Wheel Bearings?...or something else?? (Honduh Uhcord)
most likely you called it, it sounds like its the bearing to me too, if u jack up rear driver side and try to shake the rim and there is play in it then its def the bearing. Thats where e-brake sliding will get ya !
Old Oct 20, 2007 | 08:27 PM
Stealthman80's Avatar
is it the tire or the whole wheel? are the lugs tight?
Old Oct 20, 2007 | 09:57 PM
SOHCMAN's Avatar
Default Re: Wheel Bearings?...or something else?? (NeKe1point0)
That or it could be a bent/broke suspension piece, especially the rubber conections could be deteriorated and let the wheel wobble. But check bearings also...
sohc
Old Oct 21, 2007 | 04:04 PM
LS-V_T_fullrace_EG's Avatar
Default Re: Wheel Bearings?...or something else?? (SOHCMAN)
just replaced the swingarm bushings on my DA and fixed this problem... they are a pain to do without using a bearing press though
Old Oct 21, 2007 | 07:37 PM
Default Re: Wheel Bearings?...or something else?? (LS-V_T_fullrace_EG)
well i bought a whole new hub and arm assembly on ebay...you think i can just put it all in and it'll work good for me?? or what??
Old Oct 21, 2007 | 07:39 PM
ok...well i jacked it up and the tire has no play...so im guessin its not the bearing...so im thinkin its probably my suspension...i have a whole hub assembly and swing arms and stuff so i think im gonna replace that...you think thats a big job???
Old Oct 22, 2007 | 09:54 AM
did u inspect the bushings and major components of the suspension when u had the car up ? id still replace the bearing just to be sure. Survey the area look for any missing nuts, and anything that doesnt look right.
i know when i had to replace some stuff on my suspension i let a buddy do one side and turnd out he accidently used a different nut on the radius rod and it backed out and caused all sorts of problems instantly while i was driving one day.
better safe then sorry ya know.
so def just take a good look under there.
Topnotcheez
Acura TL, RL & ZDX
17
Jun 23, 2009 09:08 AM
EJ8 GSR-T
Feb 22, 2009 05:28 PM
EJ8 GSR-T
Sep 29, 2008 03:24 PM
The Flying Dutchmen
Jul 29, 2005 07:56 AM
Charlie Moua
Sep 13, 2002 04:56 PM
