89 Si overheating
Old Oct 20, 2007 | 10:30 AM
Gvis420's Avatar
Default 89 Si overheating
Can anyone pls help! I just bought this Civic, The guy was running only water in the coolant. I drained it and didnt fill or bleed it properly or something, now when i drive it it overheats. If i let it idle it slowly cools. when it overheats the overflow container bubbles and the top hose is the only one hot! My fan does come on but it dosent blow warm air inside only cold. I try to bleed the system but only steem comes out no fluid. I see alot of info on blown head gaskets, i havent driven it hard yet so i should be that. Any help would be great! Thermostat? Bleed it more? More Coolant?
Old Oct 20, 2007 | 10:52 AM
01_CLtypeS's Avatar
Default Re: 89 Si overheating (Gvis420)
try posting in the 88-91 thread you'll get more help there
------> https://honda-tech.com/zeroforum/3
Old Oct 20, 2007 | 10:58 AM
Syndacate's Avatar
Default Re: 89 Si overheating (01_CLtypeS)
Leave the cap of the radiator off while it's idling to make sure all the air gets out of the system.
More coolant? The coolant level should be filled to the neck of the radiator while the car is running, after it doesn't go down anymore, fill the reservoir almost up to the "top" mark (or if it's already at standard operating temperature, AT the "top" mark).
I just re-read.
If you're going to drain the coolant and NOTHING comes out - that means you have a serious ******* leak - simple as that. No headgasket, no slow burn, no air in the system, if no liquid's coming out - you're losing it all, plain and simple.
Old Oct 20, 2007 | 11:02 AM
Gvis420's Avatar
Default Re: 89 Si overheating (Syndacate)
i wasnt tring to drain i was tring to use the bleeder screw on the hose. only vapor is coming out no fluid.
Old Oct 20, 2007 | 11:05 AM
Gvis420's Avatar
from cold, how long do i let it run with the rad cap off and bleeder screw open to bleed it properly?
Old Oct 20, 2007 | 02:37 PM
builthatch's Avatar
MiG-21 superfan
WRONG FORUM
moved.
2000eK_cIvIc
13
Apr 19, 2011 05:04 PM
corince06
Jun 11, 2008 12:48 PM
Gvis420
Oct 22, 2007 09:48 AM
Gvis420
Oct 21, 2007 05:42 PM
CDtegGo
Aug 27, 2006 02:22 PM
