tapping and i just did a compression test
Old Oct 20, 2007 | 10:16 AM
mattv's Avatar
Default tapping and i just did a compression test
it read 180, 180, 180, 180, 125 from left to right. and its a d16z6. i almost hydro locked it yesterday. now its tapping, any ideas?
Old Oct 20, 2007 | 10:24 AM
ariza034's Avatar
Default Re: tapping and i just did a compression test (mattv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattv &raquo;</TD></TR><TR><TD CLASS="quote">it read 180, 180, 180, 180, 125 from left to right. and its a d16z6. i almost hydro locked it yesterday. now its tapping, any ideas? </TD></TR></TABLE>
wow u have 5 cylinders
just kidding but if you almost hydrolocked it it could be rings ,bearings .... do a leak down test
Old Oct 20, 2007 | 10:45 AM
mattv's Avatar
oops yea sorry 180, 180, 180, 125. but if it was the ring you couldnet hold 180 compression with bad rings. bearings would make a knock.. this is a tap. but thx. anyone else?
Modified by mattv at 11:58 AM 10/20/2007
Old Oct 20, 2007 | 11:03 AM
mattv's Avatar
anyone?
Old Oct 20, 2007 | 11:05 AM
Syndacate's Avatar
Default Re: (mattv)
Do a leakdown test, it's either the rings or the valve seals.
nicks-eg6's Avatar
Default Re: (mattv)
check your valves
Old Oct 20, 2007 | 11:10 AM
mattv's Avatar
thanks. im lookin into it now. but its tapping. and i dont think that can cause a tap. if you think it can please elaborate on it. thank again
-matt
Old Oct 20, 2007 | 11:15 AM
mattv's Avatar
actually im almost positive that neither of those to reasons would cause a tap. so it must be something else.
Old Oct 20, 2007 | 12:02 PM
mattv's Avatar
????? any1 else heh
Old Oct 20, 2007 | 03:30 PM
SiR Koopa's Avatar
Default Re: (mattv)
u could have more then one problem, find out where ur leaking then find out about the tap? i was reading some where else that bent valves can cause tapping, which would probly cause ur 125 issue too maybe?
Modified by SiR Koopa at 5:34 PM 10/20/2007
Old Oct 20, 2007 | 06:41 PM
blk92_d16's Avatar
Have you drained, flushed, and refilled with new oil yet? and just curious, how did you "almost" hydrolock it? Flooded street?
Old Oct 21, 2007 | 05:25 AM
mattv's Avatar
yes huge puddle. i didnt see it till last minute and i put it in nutral. and yes i already did an oil change.
Old Oct 21, 2007 | 05:31 AM
mattv's Avatar
im pulling the head rite now. so ill see whats goin on
Smash03
Aug 24, 2008 11:21 PM
humboldt_skim
May 31, 2008 08:18 AM
Got_soy
28
Aug 8, 2005 12:49 PM
RedRacerCivic
11
May 22, 2003 10:29 AM
gsr~hatch
Apr 17, 2003 03:19 PM
