Question: P29 Pistons
Old Oct 20, 2007 | 10:14 AM
Dante Civic's Avatar
Default Question: P29 Pistons
hey wassup people..
just wanted to know if I can use the p29 pistons on my jdm d15b vtec block.
if yes, what rings / rods do you suggest?
c-ya around
Old Oct 23, 2007 | 06:11 AM
up...
anyone!!?
Old Oct 23, 2007 | 07:05 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: Question: P29 Pistons (Dante Civic)
They are the exact same 75mm bore size, so yes the P29s will fit in the holes. I know on non-VTEC blocks the pistons actuallt sit too low in the cylinders, but I've heard that they work fine in the JDM VTEC D15B and VX D15Z1 VTEC-E blocks.
I have no clue on the compressin ratio though - I can only imagine it'd be something crazy.
I'd do some research on the D series message baord before commiting to any build, because honestly I'm not 100% sure they're a okie dokie piston for that engine.
Modified by B18C5-EH2 at 11:19 AM 10/23/2007
Old Oct 23, 2007 | 07:36 AM
chadalac1712's Avatar
im putting p29s in my d16z6 in about 3 weeks. im using stock rods and it came with rings. if you do have to buy rings seperately buy for a d16a1 outa a 1989 acura integra
Old Oct 23, 2007 | 07:39 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: (chadalac1712)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chadalac1712 &raquo;</TD></TR><TR><TD CLASS="quote">im putting p29s in my d16z6 in about 3 weeks. im using stock rods and it came with rings. if you do have to buy rings seperately buy for a d16a1 outa a 1989 acura integra</TD></TR></TABLE>
Correct about the rings, but the question is still there about compatibility with a 1.5L block.
Old Oct 23, 2007 | 11:52 AM
Default Re: (B18C5-EH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 &raquo;</TD></TR><TR><TD CLASS="quote">
Correct about the rings, but the question is still there about compatibility with a 1.5L block.</TD></TR></TABLE>
yes, actually i know some people around rocking those p29 pistons with d16 blocks..
thats why im asking if they will work/fit fine on a d15b vtec block
btw.. thanks for the tip of the rings...
Old Oct 23, 2007 | 11:57 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: (Dante Civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dante Civic &raquo;</TD></TR><TR><TD CLASS="quote">
btw.. thanks for the tip of the rings...</TD></TR></TABLE>
Ahh yes the P29s are great - I know:
I've been driving my D16A6 with P29s in my daily driver for over 4-5 years now with zero issues. I just compression tested it the other day and it was a solid 250psi across all 4 cylinders!
Old Oct 29, 2007 | 06:59 AM
wow..
that ones looks great...
love the work on the block ahaha
im asking about this, cause i own a jdm d15b vtec engine..
just looking information if the p29 pistons fits well with the d15b block and head...
Old Oct 29, 2007 | 07:27 AM
Padawan's Avatar
Darth ModerVader
Nice photos. Did you do any work on them to remove sharp edges (e.g., around the valve reliefs), or is that the way they come from Honda?
Old Oct 29, 2007 | 08:00 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">Nice photos. Did you do any work on them to remove sharp edges (e.g., around the valve reliefs), or is that the way they come from Honda? </TD></TR></TABLE>
They came out of the boxes like that.
Old Dec 13, 2007 | 02:01 PM
anybody, real sure about this??
another question for you guys... is the d15b vtec head the same as the d16z6 one?
Old Dec 13, 2007 | 02:35 PM
trrbl1bmx's Avatar
I again can vouch for the P29's in a 1.6L block but I haven't the first clue about 1.5L.... Check bore size!!
Old Dec 13, 2007 | 04:19 PM
yes it will work...just use your stock rods and you will be fine...you will have alittle lower compression...almost same as a type-r 11:5 instead of 12:6 in the z6 block...also z6 rods and stuff will work....lemme know bc i got brand new 1's with rings and everything fs...1 needs a new rod bc it was bad but the pistons are brand new...already mounted on 3 pistons
92hondaswap
15
Apr 24, 2011 10:04 AM
attica
Dec 21, 2010 06:11 AM
JBLAZE622
Dec 24, 2007 03:41 PM
Project_EK
Feb 3, 2007 10:20 AM
I_got_your_honda
Aug 17, 2006 01:04 PM
