Speedometer died... came back to life.
Old Oct 19, 2007 | 01:30 PM
beoy9's Avatar
Default Speedometer died... came back to life.
I've had this issue a few times in 2 different civics and i'm just wondering if anyone knows any good fixes for it.
This morning I'm driving along 80mph and then all of the sudden the speedo just shuts off and falls to 0. About 10 minutes later it wakes up and bounces from 0 to 10 to 5 to 40 to 15 to 65 to 30 then stayed steady at 80 till I got off the freeway. I've also had it at other times just bounce up and down like that for a few minutes and then goes away.
Anyone have any ideas?
Thanks.
Old Oct 19, 2007 | 02:11 PM
1992Si's Avatar
VSS
Vehicle speed sensor or speedo
Old Oct 19, 2007 | 03:47 PM
slowcivic2k's Avatar
Default Re: Speedometer died... came back to life. (beoy9)
Check the VSS connector. 9/10 cases that I see the pins rust away inside the connector, causing the blip of the speedo.
Old Oct 19, 2007 | 04:09 PM
speedooo's Avatar
Default Re: Speedometer died... came back to life. (slowcivic2k)
had the same issue...changed the plug on the harness
Old Oct 19, 2007 | 04:15 PM
95jdmcivic's Avatar
mine did that when my altanator ground wasn't all the way grounded and caused my car to run off battery thus causing the spedo and tach to jump all around and die and come back.
Old Oct 19, 2007 | 04:52 PM
Default Re: (95jdmcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95jdmcivic &raquo;</TD></TR><TR><TD CLASS="quote">mine did that when my altanator ground wasn't all the way grounded and caused my car to run off battery thus causing the spedo and tach to jump all around and die and come back.</TD></TR></TABLE>
The alternator grounds off the block, so I'm assuming your alternator was not properly affixed to the engine. The only feasible way that could happen is if your alternator died, and you killed the battery while driving...
Don't post if you don't know what your talking about.
Old Oct 19, 2007 | 05:16 PM
miamijdmcoupe524's Avatar
Default Re: (slowcivic2k)
mine was also the VSS connector, figured it out after i started using Honda-tech
Old Oct 23, 2007 | 11:47 AM
beoy9's Avatar
Thanks for the replies. I'll check the VSS tomorrow on my day off. That's the one that plugs into the transmission, right?
Old Oct 23, 2007 | 11:50 AM
B16B_coupe's Avatar
HRD PKR
Default Re: (beoy9)
yes the vss is normally a 3 wire plug towards the rear off the tran's.
most the time coolant or some fluid gets in there and cause's the pins in the vss to corrode, when you install your new one fill the plug with dieletric grease
Old Oct 23, 2007 | 11:53 AM
beoy9's Avatar
So should I get a new sensor, or a new plug, or both?
Old Oct 23, 2007 | 11:55 AM
B16B_coupe's Avatar
HRD PKR
Default Re: (beoy9)
well the sensor probablu, check inside the plug and the sensor to see if its all green or corroded looking
Old Oct 23, 2007 | 12:04 PM
beoy9's Avatar
Ok, how much are those sensors and is the best place to get one the dealer?
Old Oct 23, 2007 | 12:06 PM
B16B_coupe's Avatar
HRD PKR
Default Re: (beoy9)
you can get one used on here for around 40 or 50 bucks, brand new over 100 bucks, i actually just replcaed mine and my cost was 60 or 70 dealer.
gl man
Old Oct 23, 2007 | 12:13 PM
beoy9's Avatar
Default Re: (B16B_coupe)
Thanks again.
Old Oct 23, 2007 | 12:19 PM
B16B_coupe's Avatar
HRD PKR
Default Re: (beoy9)
just make sure you look at it first, make sure it is corroded, but check the connector itself to!!!
Old Oct 23, 2007 | 01:36 PM
beoy9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16B_coupe &raquo;</TD></TR><TR><TD CLASS="quote">just make sure you look at it first, make sure it is corroded, but check the connector itself to!!!</TD></TR></TABLE>
Will do.
milkmanLCA
26
Jan 8, 2012 08:32 AM
pip9
28
Apr 11, 2006 04:30 PM
red-eg6
Jul 24, 2005 08:08 AM
CiviC RacecaR
Jun 21, 2005 03:46 AM
roycivic92
10
Jan 21, 2005 03:58 PM
