P0132 O2 error
Old Oct 19, 2007 | 01:21 PM
DJR's Avatar
DJR
Default P0132 O2 error
Hey guys, I've got a P0132 error after an aftermarket header installation on a D16Y7. This header has the O2 sensor hole by the end of the collector tube and came with the wiring extension. I've changed sensors, checked the extension wiring and still. Tried erasing the code but comes back again after a while. Might this be a sensor location problem? Any recommendations greatly appreciated.
Old Nov 15, 2017 | 10:42 AM
Sanyi's Avatar
Default Re: P0132 O2 error
Hello,
Your message quite old, You managed to solve the problem I guess...(?)
I have a similar problem. I got P0132 error message, so I have replaced the primary O2 sensor with a new one, (same Denso type as original), but the problem is still coming. After deleted the error code and started the engine, the error code came back some minutes later.
Also, I replaced the secondary O2 sensor too (because I had a P0141 error code too). That problem solved. But the PO132 remaining...
Engine is D16W7 (2002 Honda Civic);
Anyone has advice?
Thanks in advance.
Sandor
cadeMFjohnson
May 12, 2009 05:17 PM
crf450ex
Feb 26, 2006 07:15 PM
SLO Sol
Oct 24, 2005 09:59 PM
d16vtecx
Oct 13, 2005 09:41 PM
wootcivic
Nov 29, 2004 10:01 AM
