heater not heating
Old Oct 19, 2007 | 12:44 PM
dmpd_ef's Avatar
Default heater not heating
when i turn the heater on in my da it doesnt blow hot air, i know its not the linkage from the **** to the valve because i just checked and it does turn it. does anybody have any suggestions on what it could be?
Old Oct 19, 2007 | 12:48 PM
pdotjones's Avatar
Default Re: heater not heating (dmpd_ef)
do you have a thermostat in your car?
Old Oct 19, 2007 | 12:57 PM
dmpd_ef's Avatar
Default Re: heater not heating (pdotjones)
it should. it warms up to operating temp in the same time as all my other cars. but i will look into it just in case.
Old Oct 19, 2007 | 01:15 PM
pdotjones's Avatar
check to mke sure. i had the same problem with my ef. come to find out there was no thermostat. after i replaced it, filled the car with coolant, and voila i had heat....also, if you do have a thermostat, and it still not blowing hot air, you might want t o flush the heater core. i've heard that those get clogged and blocks heat from entering the cabin.
Old Nov 16, 2007 | 01:21 PM
CD5-n-AP1's Avatar
I picked up a 95 LS a couple of weeks ago and my heater is not blowing out hot air either. Is flushing the core the same procedure as flushing the whole system? I recently replaced the thermostat cause the old one wasnt letting the car warm up to operating temp.
thanks
Old Nov 16, 2007 | 01:38 PM
nokia87's Avatar
look at ur heater lines see if thier not connected back to each
other.
Old Nov 16, 2007 | 11:06 PM
God-Driven's Avatar
yea check the hoses make sure both are conected one coming in and one coming out, I had a Jeep Cherokee coming in the shop with the same problem, no heater, and when I checked the hoses they had bypass the heater core cuz it was leaking, thats why they sold it, it was funny.
Old Nov 17, 2007 | 09:48 PM
Carsonteggy's Avatar
i had the same problem with my terga, i added coolant but it didn't help' my thermostat was replaced water pump and everything, Comes to find out it was an electrical problem that opens the valve that lets the cold air blow through the heater core. thats like a bubblegum and tape fix lol, an indication of that problem was the lights over the vent selection panel would flicker the whole time the car was on, also when you hit those buttons the vents dont change until you beat the **** out of it. if you have that problem i suggest you check that temperature selection panel.
sickofitall1113
Feb 12, 2011 08:11 AM
flatblk
Dec 7, 2006 12:04 AM
love4cars
Dec 27, 2004 05:11 PM
superstud
Mar 14, 2004 08:54 PM
BigChris
Apr 26, 2003 01:50 PM
