odd knock sensor problem
Old Oct 19, 2007 | 09:59 AM
b16a3delsol's Avatar
Default odd knock sensor problem
The cel only comes on when at idle. It doesnt act up any other time. does this sound like a typical knock sensor problem and if so whats the best fix. thanks
Old Oct 19, 2007 | 11:00 AM
Default Re: odd knock sensor problem (b16a3delsol)
any help at all
Old Oct 19, 2007 | 06:39 PM
maybe no one knows the answer
Old Oct 21, 2007 | 01:26 PM
If this helps it happens when idling at around 800rpm at 1000 though it is fine. any ideas.
Old Oct 21, 2007 | 03:03 PM
slowcivic2k's Avatar
Might want to look at the stickies at the top to find out what your CEL code is for, instead of guessing.
Old Oct 21, 2007 | 05:54 PM
Default Re: odd knock sensor problem (slowcivic2k)
Ive checked it. I know it is the knock sensor that is why im asking if that is a common problem.
Old Oct 21, 2007 | 05:56 PM
drSquish's Avatar
try changing the knock sensor and go from there
Old Oct 21, 2007 | 05:59 PM
Default Re: odd knock sensor problem (drSquish)
Is it possible it could be in the wiring? Im planning on chipping the ecu in the future anyhow.
Old Oct 21, 2007 | 06:03 PM
drSquish's Avatar
yes, that is very possible. nothing is perfect and everything breaks sooner or later.
Old Oct 21, 2007 | 09:07 PM
Default Re: (drSquish)
The wiring is one of those one off i had to wire it in myself jobs. could the resistance be off. or something odd.
Old Oct 22, 2007 | 07:06 AM
drSquish's Avatar
in your situation, i'd expect that the resistance wouldn't affect the signal unless it is extremely high. I work with electronics on a daily basis. All it really takes is one wire to get cut by an abrasive part of your chassis.
Old Oct 22, 2007 | 07:39 AM
there not cut i just recently ran them with new wire and they didnt work to begin with.
Old Nov 3, 2007 | 10:57 PM
xtcxjigga's Avatar
Default Re: (b16a3delsol)
my cel code 23 only comes on when i rev past 3k or hold it around there for 10 secs. are you sure you are getting a cel for the ks?
Old Nov 4, 2007 | 03:51 AM
instrument's Avatar
did you use shielded wire?
did you solder or simply twist it?
and did you shrink wrap it?
i had the same issue because i didn't shrink wrap it, someone told me the wire had to be shielded or something, i figured it was worth the effort so i went ahead and shrinkwrapped it and its worked fine ever since.
Old Nov 4, 2007 | 06:51 PM
xtcxjigga's Avatar
Default Re: (instrument)
hey instrument, you think this will work on a F22b engine ? i've had no luck so far. i did it with so many different types of wire already, except shielded. maybe i should really see if there is a voltage going through it. do you have a pic handy of your setup ?
Modified by xtcxjigga at 10:32 PM 11/4/2007
b16a3delsol
Oct 21, 2007 08:11 AM
but
Sep 29, 2006 05:22 AM
wizzards581
14
Jul 5, 2005 11:03 AM
lowexr
Jul 23, 2003 04:58 PM
