Diffrence between manual motors and automatic motors
Old Oct 19, 2007 | 06:31 AM
Acidcrakker's Avatar
Default Diffrence between manual motors and automatic motors
Okay so I got a new motor on the way, and apparently its off an automatic. I have a 5-speed. The guy that sold it to me, said all i have to do is change the fly wheel, is this true. Im asking early cause my swap isnt happening till end of month.
Old Oct 19, 2007 | 06:51 AM
98vtec's Avatar
moderator emeritus
Default Re: Diffrence between manual motors and automatic motors (Acidcrakker)
take everything off til you get to the main seal and you have a 5 speed block.
Old Oct 19, 2007 | 07:02 AM
Eddiebx's Avatar
also something to keep in mind is, when putting on a flywheel to replace the AT torque plate, get new flywheel bolts, because the ones that hold the AT flex plate to the crank are shorter than the ones that hold a flywheel to the crank.
Old Oct 19, 2007 | 07:14 AM
94Vtecluder's Avatar
How much did you pay? Did you get it from that guy in Jersey I told you about?
Old Oct 19, 2007 | 07:51 AM
Default Re: Diffrence between manual motors and automatic motors (94Vtecluder)
Well I spent 900 on the motor and 200 on the ECU. He is shipping it for free. Yeah same guy, they seemed honest enough. Thats for the info.
Now All I need is a new flywheel and the pins to wire Vtec.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94Vtecluder &raquo;</TD></TR><TR><TD CLASS="quote">How much did you pay? Did you get it from that guy in Jersey I told you about?</TD></TR></TABLE>
Any suggestions on flywheels? I hear that the fly wheel and clutch should be upgraded at same time.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddiebx &raquo;</TD></TR><TR><TD CLASS="quote">also something to keep in mind is, when putting on a flywheel to replace the AT torque plate, get new flywheel bolts, because the ones that hold the AT flex plate to the crank are shorter than the ones that hold a flywheel to the crank.</TD></TR></TABLE>
Old Oct 19, 2007 | 09:49 AM
cb7tougeracer's Avatar
depends on what your doing with it i say with a few bolt ons use the exedy stage 1 clutch and flywheel
Old Oct 19, 2007 | 10:02 AM
Default Re: Diffrence between manual motors and automatic motors (cb7tougeracer)
How much does that actually n. It will be a few bolt ons w/nirous tned with Hondad s200 when its done.
Also I really need the Vtec Pins to wire up my Vtec, any suggestions if
I cant get the pins.
Old Oct 19, 2007 | 10:08 AM
Hawkze_2.3's Avatar
I'd get a Fidanza 8lb flywheel and Exedy stage 1 or 2 clutch.
Old Oct 19, 2007 | 12:38 PM
E-Money's Avatar
Default Re: Diffrence between manual motors and automatic motors (Hawkze_2.3)
i would suggest a aftermarket flywheel and a oem clutch setup
Old Oct 19, 2007 | 05:42 PM
M2B4's Avatar
Default Re: Diffrence between manual motors and automatic motors (E-Money)
im with hawk. if i remember me and him are running same setup. fidanza 8lb and stage 2 exedy feels great
Old Oct 19, 2007 | 05:50 PM
Default Re: Diffrence between manual motors and automatic motors (M2B4)
Well Il probally do the flywheel, but not the clutch. I think I have like 400 bucks left to complete my set up for November. The only thing that I have left to do for the year after the swap is tune with s200. I was thinking of getting the hondata software just to play with cause Im not capable of using that software right now with my current skills.
Old Oct 19, 2007 | 08:40 PM
M2B4's Avatar
i got my exedy stage 2 and 8lb fly for 500 shipped
SkylerTheG
Transmission & Drivetrain
Jul 20, 2013 03:36 PM
MadCityLude
Sep 27, 2006 09:19 PM
ITR-2001
Aug 16, 2006 02:02 PM
ilu
Apr 12, 2006 01:05 PM
mingbling96
Mar 13, 2005 02:08 PM
