hmm Thermostat removal... benefit?
Old Oct 18, 2007 | 07:27 PM
1a's Avatar
1a
Default hmm Thermostat removal... benefit?
Ok so my car overheats sometimes but goes down when I turn the heat on.... damn hot weather... but I was at a car meet tonight... and my buddy told me that I should just remove the thermostat until fall is over...
1. what benefits do I gain? someone said power gain.
2. what do i need to make sure to do to make my motor ok still..
3. is this true that it will not overheat?
Old Oct 18, 2007 | 07:34 PM
denraweb's Avatar
Default Re: hmm Thermostat removal... benefit? (mck52689)
Don't do it. Your car will overheat...think about it. If you take out your thermostat then the coolant will flow constantly right? Ok, great, constant coolant means cooler engine, right? Wrong...with the thermostat gone, it can't stop the coolant and let the radiator cool it off. It shoots through the radiator and just keeps getting hotter and hotter as it traps the heat from the engine never cooling off due to not stopping in the radiator...leave the thermostat in.
People always wonder why their cars overheat after removing the thermostat. Well, that's why.
Old Oct 18, 2007 | 07:37 PM
1a's Avatar
1a
hm dammit i hate when idk whos right haha... well im still debating... i know some people who took it out and it worked... hm
Old Oct 18, 2007 | 07:38 PM
DOHCgarage919's Avatar
From: Why To Steal My Car, NC, United States Of America
Default Re: hmm Thermostat removal... benefit? (denraweb)
damn i never even knew u cud remove the thermosat i always thought it shud be in there for a reason thats y when i saw this post i was like no u need a thermostat
Old Oct 18, 2007 | 07:41 PM
Default Re: hmm Thermostat removal... benefit? (DOHCgarage919)
if your car overheats then something else is wrong cuz my gsr never overhated even when it was 105 degrees outside it didnt overheat well i built my motor and got a new thermostat from acura dealer i think all u need is a new thermostat or something else is causing it to overheat but taking it out i think is just plain stupid its in there for a purpose not for whatever...
Old Oct 18, 2007 | 07:43 PM
1a's Avatar
1a
http://www.fiatforum.com/cinq-....html
somewhat what i mean... idk it has some reason but at the same time in my opinion i am thinking is one of those pieces... that doesnt hurt to have gone...
Old Oct 18, 2007 | 07:47 PM
ya but my car never overheated not even when it was 105 outside something is wrong with ur motor or ur radiator cuz a motor shudnt be overheating for no reason its something and it can be fixed but not by removing the thermostat- im i right or im i right????
Old Oct 18, 2007 | 07:50 PM
1a's Avatar
1a
yea well half and half... my friend had the same problem with his dc and he told me it worked when he removed it..
Old Oct 18, 2007 | 08:14 PM
well somethings wrong with his too a normal car shudnt be overheating somethings wrong please someone back me up on this mines never overheated and it had an old thermostat maybe u need a radiator flush
Old Oct 18, 2007 | 08:19 PM
1a's Avatar
1a
what years your integra... and miles wise... mine is a 91 with 256 but 87 on the engine
KBG Indey's Avatar
when i bought my miata it had no thermostat
the only difference was it took longer to warm up since the coolant was constantly flowing
as for the above comment about it not letting it stay in the radiator, im not sure if you know, but the coolant just instantly flows through the radiator and back into the motor.
REGARDLESS of if theres a thermostat or not
theres no valve at the bottom of the radiator that keeps it INSIDE it until its cool then cycles it through the motor
If you want to remove it you can, but remember honda put it there for a reason, and realistically if you're overheating you might want to check for other reasons as to why instead of just taking out your thermostat
power gains? never heard of that one, i don't see how you could gain any kind of power from having it constantly flowing in compared to not.
considering the fact that inside the thermostat is wax that melts under a certain temperature, which causes the thermostat to expand and allow coolant to flow to the radiator
it wont cool any more or any less than it would in there or not
so i'd say just look for real reasons as to why your cooling system may be over heating, hell your thermostat could be stuck closed and not allowing the coolant to flow to the rad, you could have a small break in the system, or air in the system. don't just remove components
Old Oct 18, 2007 | 08:23 PM
Default Re: (KBG Indey)
AMEN!!!
Old Oct 18, 2007 | 08:25 PM
Default Re: (DOHCgarage919)
o by the way my gsr is a 94 with 170k on chassis and my motor is off a 2000 gsr with 106,000 miles yes urs has more miles and is older but doesnt change the fact that something else is wrong and removing componets isnt the answer.
linkdeezie
May 14, 2019 11:49 AM
jwlee7ucla
Aug 7, 2007 03:48 PM
Arch-Angel
Dec 24, 2004 03:08 PM
dkdjlf
Aug 14, 2003 10:34 AM
kpxgq
Dec 25, 2002 04:37 PM
