gsr rod bearings in a lsvtec?
Old Oct 18, 2007 | 07:16 PM
blackcrx16's Avatar
Default gsr rod bearings in a lsvtec?
every one i talked to said use gsr rod and main bearings in my ls vtec so i bought the rod bearings and just now i was foolin around with one of the ls rods and gsr bearings and i noticed that the rod bearing does not have a hole in one of them. the rod has a hole in it and the gsr rod bearings dont have that hole. please explain to me what i did wrong.
Old Oct 18, 2007 | 09:08 PM
myfirstdc2's Avatar
Default Re: gsr rod bearings in a lsvtec? (blackcrx16)
did u also notice that the gsr bearing is alot narrower than the ls?
Old Oct 19, 2007 | 06:44 AM
evildc2's Avatar
Bad really bad they are not the same,dont even keep trying,if you want stronger bearings try <U>acl race series </U> this are as strong as vtec bearings but make sure they are race series they came in a yellow box and get them for LS not for anything else, also be safe and use arp rod bolts and keep it under 8500rpm if your using LS rods,good luck
Old Oct 19, 2007 | 01:53 PM
blackcrx16's Avatar
Default Re: gsr rod bearings in a lsvtec? (evildc2)
i have arp rod bolts and arp head bolts. whats this machining of the rods when installing arp rod bolts? what exactly do they machine and what happens if i dont get it done?
m88ulrich
Engine Machining & Assembly
Mar 30, 2018 08:39 PM
lriver0001
Apr 29, 2011 07:10 AM
DC2 Mang
15
Oct 22, 2005 10:07 AM
turboteggsr
Jun 9, 2004 01:15 PM
b16vtecsol
Apr 28, 2004 04:01 AM
