blowing ecu fuse... WTF?!
Old Oct 18, 2007 | 05:24 PM
j-specB20sol's Avatar
Default blowing ecu fuse... WTF?!
I finally got the car started and it ran for a little while but would not rev very well... turned it off came back 20 minutes later and it wouldnt start. checked the fuses and the ecu 15a was popped. replaced it and turned the key on... POP. that one went too. so i replaced it one more time with a 20a and that one lasted about 2 seconds longer and it eventually popped as well.... any ideas? its a short to ground somewhere i know but has anyone had anything similar happen?
Old Oct 18, 2007 | 05:29 PM
Default Re: blowing ecu fuse... WTF?! (j-specB20sol)
i had a battery charger on it for a little while if that has anything to do with it?
Old Oct 18, 2007 | 05:47 PM
spray_bombed's Avatar
never had that problem but it sounds like your gonna have a fun time tracing wires....good luck man
Old Oct 22, 2007 | 01:21 PM
Default Re: blowing ecu fuse... WTF?! (spray_bombed)
am i the only one thats had this problem?
Old Oct 22, 2007 | 01:39 PM
B18C5-EH2's Avatar
Former Moderator
Loved
NEVER EVER EVER replace a fuse with a fuse with a higher amperage. you are asking for a fire, metlted wires, possible damage to the ECU, etc. etc.
Sounds like you have something grounding out - check the secondary oxygen sensor wires under the car. They can short out and pop ECU fuses like a **** y0.
Old Oct 22, 2007 | 01:58 PM
MiamiEgGSr's Avatar
Default Re: blowing ecu fuse... WTF?! (B18C5-EH2)
dude the same thing happen to me , when i got back my 92 accord years ago.. I spent the whole day searching until i found the cable , it was crimped under the strut bar!!!!!!!!!
Old Oct 22, 2007 | 04:20 PM
Mr Marcin's Avatar
i had the same problem about a week ago and did the same thing as you.... the problem was that i put a ITR header and the O2 sensor on the header was causing the ecu fuse to keep popping every time i got into vtec... and then it got so bad that it wouldnt start... i only replace the fuse like three times...but it took me so long to figures out wtf was the problem
Old Oct 23, 2007 | 12:44 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 &raquo;</TD></TR><TR><TD CLASS="quote">NEVER EVER EVER replace a fuse with a fuse with a higher amperage. you are asking for a fire, metlted wires, possible damage to the ECU, etc. etc.
Sounds like you have something grounding out - check the secondary oxygen sensor wires under the car. They can short out and pop ECU fuses like a **** y0.</TD></TR></TABLE>
yeah i know im an idiot for doing that lol... but i was just figuring since i had a new ecu that was chipped maybe it drew more amperage... but looking back that makes ZERO sense... so yeah ill wear the dunce cap for a few minutes for upping the fuse amperage
Old Oct 23, 2007 | 08:06 AM
Mr Marcin's Avatar
try unpluging the O2 sensor and try to start your car...it worked for me
Old Oct 23, 2007 | 09:01 AM
Nbboy7's Avatar
had the same problem my o2 would ground out pop the ecu fuse
Old Oct 23, 2007 | 04:37 PM
Default Re: (Nbboy7)
sounds like EVERYONE is saying o2 sensor... im gonna have to check that when i get to my car next!
Joshb152
Oct 9, 2015 09:10 PM
hoursinexile
Nov 17, 2009 10:14 AM
EGKREW
Dec 20, 2008 05:25 PM
crxdude
16
Jun 5, 2007 05:18 PM
nota-eg
Jul 19, 2005 10:57 AM
