omg my clutch
ok so iam stuck...i have a 96 prelude...f22
...lastnite i was out driving and had no problems, everything felt good in the pedal no problems shifting...(and i dont race the car cause its so slow, so i wasnt beating on it)...but anyways so i come out this mourning and get reasdy do go to work and my clutch pedal feels really loose, and its not disengaging so i cant even get it in gear...so i checked to see is my clutch cable was loose maybe but not...didnt have time to really look at it cause i was a half hour late for work and i needed to find a ride...so tonite i go out to my car and step on the clutch to start the car and when i let up the pedal stays down
...so iam things maybe throwout bearing(release bearing)..or jus my clutch is shot...any1 have any idea or maybe know what it is???please...so i can fix untill i get the money for my H22
You should try to search next time
.......... https://honda-tech.com/zerothread?id=1787746
If that doesn't help, then there are 25 other topics in the Prelude archived section about "clutch pedal"
hows ur clutch fluid? its probably empty lol
I'd look for leaking clutch fluid first. I had a leak right under the resivoir (fill spot) on the line that comes out the bottem (one with screw clam on it). Could be your master and slave clutch cylinders aswell. Look for bleeding around your clutch peddal's cylinder under your left foot. Both clutches at a shop will run you around 250-300 or you can DIY pretty easily even with a Hanes or Chilton.
It's either your *clutch* master cylinder or your slave cylinder. The master has one pain in the *** bolt to get off.
I'm willing to bet that one of the two if not both is your problem, if it's not your fluid. Check easy things first.
well my clutch is back no normal i know thats not the end of it...how do i fix this...i have a leak coming from my dust shield covering my flywheel...so what can that be...but it could be leaking down from my slave cylinder...someone please help....what do i replace...clutch, slave cylender, release bearing...???what???
djsire
Sep 7, 2005 04:14 PM
you better hope its running down the block somewhere and that its not your rear main seal.
