P0141 oxygen sensor
Old Oct 18, 2007 | 11:57 AM
pos_cd5's Avatar
Default P0141 oxygen sensor
so my grandmas 03 Accord LX I4 just threw its first check engine light the other day. the code was P0141: heated oxygen sensor bank 1 sensor 2. i'm not too familiar with the 7th gens (or any OBD2 car for that matter) but is there 2 or 3 02 sensors? if there is 3, is the code refering to the one in the cat or the one after the cat.
the car also only has 32k miles on it, so im surprised its already throwing the code. but im going to check the simple stuff first, fuse, loose/broken wires, etc. any suggestions before i throw down $100 for a new 02 sensor?
Old Nov 3, 2007 | 03:21 PM
dc2go's Avatar
that code isnt exactly a fix by replacing the o2 sensor..its some wire loose/broken...
is there a way to diagnose where the loose wire is at? anyone? i also have this P0141 BS..
Old Nov 4, 2007 | 04:34 PM
JimBlake's Avatar
Default Re: P0141 oxygen sensor (pos_cd5)
There's 2 O2 sensors & that's referring to the rear one, in/after the cat.
I haven't had to do that yet on my 2003, but unfortunately I've heard you have to remove the passenger seat & look under the carpeting. Yup, the sensor wire goes thru the floorpan before you'll find a plug...
That's the code for the heater in that sensor. Get a multi-meter & unplug the sensor. There's 2 wires from the sensor itself that are the same color (black?). Measure resistance between them. It should be 10 to 40 ohms. If it's not, get yourself a new sensor. If the resistance is OK, post back for more help.
Old Dec 18, 2007 | 01:52 PM
bdiolhlerty's Avatar
Default Re: P0141 oxygen sensor (JimBlake)
im having a similar problem except the error is on the front O2 sensor (befor the CAT), any recommendations on what i should do.
thank you
Old Dec 18, 2007 | 05:52 PM
JimBlake's Avatar
Default Re: P0141 oxygen sensor (bdiolhlerty)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bdiolhlerty &raquo;</TD></TR><TR><TD CLASS="quote">im having a similar problem except the error is on the front O2 sensor (befor the CAT), any recommendations on what i should do.
thank you</TD></TR></TABLE>What kind of car?
There's 4 different error codes for the front O2 sensor. Is it the one specifically for the heater? If so, then just do the same thing as I said above.
Ryanw441
Jun 3, 2024 06:15 AM
Kentagious
Honda Civic (2006 - 2015)
Sep 22, 2016 06:41 AM
Slammed_am
May 10, 2006 02:35 AM
Ge.ES.AHH
Oct 24, 2004 07:10 PM
SmokeU
Nov 7, 2002 05:05 AM
