CEL code 41.. need help!
Old Oct 14, 2004 | 01:06 PM
Ge.ES.AHH's Avatar
Default CEL code 41.. need help!
how do i get rid of code 41. (primary oxygen sensor heater)
do i just replace my cat or first o2 sensor? or both?
my cat is rattling like crazy!
Old Oct 15, 2004 | 04:42 AM
JimBlake's Avatar
Default Re: CEL code 41.. need help! (Ge.ES.AHH)
Code 41 has nothing to do with the cat. Unplug the 1st O2 sensor, find the two same-colored wires going to the sensor. You should measure something from 10 to 40 ohms between those 2 wires, and there shouldn't be any continuity from either one to ground.
If the sensor checks out fine, you have to check out the circuit. You don't say what year car, so...? One of the wires that mate up with the heater is supposed to get battery voltage from the main relay (yellow/black??) The other one goes to the ECU. Look for a broken wire somwhere? Or maybe a short to ground in the ECU wire?
The rattling cat is not related. First check out whether it's just a heatshield rattling. If not, then maybe the A-pipe is buzzing. That's a pipe-inside-a-pipe, and the inner one can buzz against the outer one. Finally, take off the cat. If it's really rattling inside, get a new one.
Old Oct 24, 2004 | 07:10 PM
krazie1's Avatar
BANNED
Default Re: CEL code 41.. need help! (JimBlake)
oh thanks for u telling or writting this up as I am having problems with my o2 and the jumper harness can't get rid of it (code 41)
will check this out tomorrow
Dr. Willy
19
Jul 21, 2010 06:48 PM
thanh4o8
Sep 28, 2009 09:17 PM
pos_cd5
Dec 18, 2007 05:52 PM
Another_Teg_Owner
Dec 15, 2003 11:11 PM
dohc-nyne
May 20, 2003 04:07 AM
