what cams?
Old Oct 18, 2007 | 10:02 AM
hellakapps's Avatar
Default what cams?
i've got 84mm ge b-16, 9:1, ported b-16 head s2 springs and retainers, 68mm tb, s2 im,power fc, avc-r, percision 1000cc, walbro 255. it's all motor at the moment but is gettin a top mount with a 70 trim t3, i have the s2 stage 2 turbo cams and the more i hear about them the less i like them. the goal for the setup is mid to high 500's . i was wondering what cams i should run to get the most out of the setup, i want something a bit more aggresive than the ctr's is there anything out there that would be better
Old Oct 18, 2007 | 12:08 PM
BryanM.'s Avatar
Resident Gearhead
Default Re: what cams? (hellakapps)
Try Brian Crower cams.
Old Oct 18, 2007 | 12:13 PM
hellakapps's Avatar
Default Re: what cams? (mcvtec)
which ones i've heard running a mild all motor cam will make more power than turbo profiles if you are runnin high boost levels.. also i can get a great deal on a set of blox b's, but do they have too much duration for boost
Old Oct 18, 2007 | 01:05 PM
all-mtr-teg's Avatar
I think i remember reading that GSR cams were good for boost, better than ITR or CTR cams
punkracer
Dec 16, 2010 08:47 PM
Spawne32
Oct 22, 2010 03:11 PM
jspeccrx91
May 12, 2010 06:41 AM
The sweed
Oct 3, 2002 08:27 AM
