Thermostat install - wrong?
Old Oct 18, 2007 | 09:43 AM
ImPuLsIvE's Avatar
Default Thermostat install - wrong?
Is there a way to screw this up? I noticed in the shop manual to install it with the 'pin up'. I tried to do this as well as I could, but it's not an easy task to do while trying to put the cover back on while the rest of the assembly is still on the engine.
Will the thermostat housing go back on properly if the thermostat isn't in there properly, or will it not fit at all.
Reason I'm asking is because I've installed the Mugen thermostat a few weeks back, but the car still managed to overheat. Would putting it in wrong have done this?
Old Oct 19, 2007 | 09:55 AM
ImPuLsIvE's Avatar
ughghghghghgh
Old Oct 19, 2007 | 10:50 AM
eggie75's Avatar
if the tstat is in rite, it will sit flush. wuts your setup? fan, rad ect. was it overheating before the tstat? did you bleed the coolant?
Old Oct 20, 2007 | 01:12 PM
AK77's Avatar
Default Re: (eggie75)
I'm having the same porblem. Was overheating, upper radiator hose hot, lower cold. Ran it without thermostat to make sure water pump is pumping and circulating coolant, its is. Does not overheat without the thermostat and both of the hoses are warm, indicating that the coolant is circulating. So I replaced the thermostat and the new one is still not openeing. The upper radiator hose is hot and the lower one cold with the new thermostat installed. What the heck could be causing it not to open?
Old Oct 20, 2007 | 01:15 PM
snowblind7x's Avatar
Default Re: (AK77)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AK77 &raquo;</TD></TR><TR><TD CLASS="quote">I'm having the same porblem. Was overheating, upper radiator hose hot, lower cold. Ran it without thermostat to make sure water pump is pumping and circulating coolant, its is. Does not overheat without the thermostat and both of the hoses are warm, indicating that the coolant is circulating. So I replaced the thermostat and the new one is still not openeing. The upper radiator hose is hot and the lower one cold with the new thermostat installed. What the heck could be causing it not to open? </TD></TR></TABLE>
put it in a pot of boiling water and watch for yourself if it opens or not.
Old Oct 20, 2007 | 01:19 PM
AK77's Avatar
It is. When installing thermostat, does the pin go up or down, up = towards the head, down = towards the block??? May be I installed the gasket incorrectly.
Old Oct 23, 2007 | 06:56 PM
DrivinVtec's Avatar
i have this motor out an i can get the damn thing together. does the 2 parts fit flush together or is there a gap because of the gasket.i gte gap. i marked up the 2 dimple things but it wont just go flush. with the stock thermo or with he new one. its pissing me off
Old Oct 25, 2007 | 04:08 PM
ImPuLsIvE's Avatar
Currently I'm running a Civic Half Rad, Slim Fan, Rad block off plate (next to radiator to force air to go through it), Mugen Thermostat, Mugen Fan switch.
Yes, it was overheating before the thermostat and the coolant was bled by taking the rad cap off and running the car with the heat/fan all the way full.
dbailey
11
Jan 30, 2020 04:27 AM
4doorpowa
Jan 24, 2011 12:50 PM
Rishiras
Acura TSX
Jan 30, 2009 06:18 PM
DRKSol
19
Mar 17, 2005 07:22 AM
dkdjlf
Aug 14, 2003 10:34 AM
