2nd Gen JDM B16 timing belt question
Old Oct 18, 2007 | 07:53 AM
P a r i s h's Avatar
Default 2nd Gen JDM B16 timing belt question
ok, now im having problems with my timing belt. I got a 99-00 si belt from honda and it seems not to match up, and keep skipping a tooth when applied. I set the motor at top dead center, and line the cam gears up with the head and when the motor is fully warmed up it just dies. Is there any other belt (beside the del sol b16a3 belt which changes over to be the same one as the 99-00) that would fit. I really need my car and this problem has been killin me.
Old Oct 18, 2007 | 08:00 AM
b16a3delsol's Avatar
Default Re: 2nd Gen JDM B16 timing belt question (P a r i s h)
if I am thinking right they are the same. you might have a different problem
Old Oct 18, 2007 | 09:01 AM
RIZOBIZERT's Avatar
I'm assuming you've replaced the tensioner pulley, spring, etc. and done the procedure correctly, right?
Old Oct 18, 2007 | 09:10 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: 2nd Gen JDM B16 timing belt question (RIZOBIZERT)
They are the same. You are doing something incorrect.
Old Oct 18, 2007 | 10:46 AM
Padawan's Avatar
Darth ModerVader
Did you follow something similar to this procedure?
http://www.c-speedracing.com/h...t.php
Old Oct 20, 2007 | 09:17 AM
I followed every step mentioned in that write up. The only thing i didnt do was replace the tensioner or water pump. But the motor was fine before the change. Also, when tightening the timing belt by turning the crank 1/8 counterclockwise and allowing the tensioner to set, does the motor need to be lined up correctly? (at top dead center and cam gears lined up to the deck?)
Old Oct 22, 2007 | 08:08 AM
anybody? Feel free to jump right in, the waters warm.
Old Oct 28, 2007 | 08:39 AM
still waitin
Old Oct 28, 2007 | 01:36 PM
Padawan's Avatar
Darth ModerVader
Default Re: (P a r i s h)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P a r i s h &raquo;</TD></TR><TR><TD CLASS="quote">Also, when tightening the timing belt by turning the crank 1/8 counterclockwise and allowing the tensioner to set, does the motor need to be lined up correctly? (at top dead center and cam gears lined up to the deck?)</TD></TR></TABLE>
Not necessarily, but the crank should be in the proper position relative to the cams.
jtwoj1
Jun 5, 2015 08:24 PM
RanCRX
Jun 1, 2014 01:41 PM
preludedriva
Jul 29, 2007 12:10 AM
mikey8422
Oct 13, 2006 12:39 AM
Panoply
May 12, 2006 12:05 PM
