<---1991 DA6 with b20 swap HELP!!
Old Oct 17, 2007 | 10:24 PM
jdmkid8383's Avatar
Default <---1991 DA6 with b20 swap HELP!!
Ok I have been driving the car and its been runnning smooth but just recently its been throwing code 17 from the ECU its a b20 OBD0 when I drive it I step on the gas drive past 15mph and it boggs out ?!?!?! Im a lost for words the code reads speed sensor but in the book it doesnt tell me about it Help me out guys...
Help me out guys I need to get her running good its my only car
Old Oct 17, 2007 | 11:25 PM
TurbdEG6's Avatar
Default Re: <---1991 DA6 with b20 swap HELP!! (jdmkid8383)
well first of all, either ditch the intake or at least replace that filter.
Second of all, the speed sensor should be behind the flock jus tbelow your IM with a clip (usually gray) on top. Remove and replace it.
If that doesn't work then I don't know why it would be throwing that code but you could always try the plugs.
Old Oct 18, 2007 | 08:12 AM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: <---1991 DA6 with b20 swap HELP!! (TurbdEG6)
+1 for the VSS
Old Oct 18, 2007 | 11:00 AM
CeReal's Avatar
Default Re: <---1991 DA6 with b20 swap HELP!! (GRAF-FITI)
ghetto fabolous
Old Oct 18, 2007 | 11:07 AM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: <---1991 DA6 with b20 swap HELP!! (CeReal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CeReal &raquo;</TD></TR><TR><TD CLASS="quote">ghetto fabolous</TD></TR></TABLE>
haha calls it like he sees it
Old Jan 7, 2008 | 03:18 PM
!!JDMBUTTMUNCH!!'s Avatar
Spark pugs try to change them!
Old Jan 31, 2008 | 09:02 PM
thcap1's Avatar
wat manifold are you running cus im doing the same swap wit a b20b running all my old parts
Old Feb 13, 2008 | 01:27 PM
tnez's Avatar
Default Re: <---1991 DA6 with b20 swap HELP!! (thcap1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thcap1 &raquo;</TD></TR><TR><TD CLASS="quote">wat manifold are you running cus im doing the same swap wit a b20b running all my old parts </TD></TR></TABLE>
x2... you should use all the old stuff (distributor, harness, ECU, sensors, etc.)
it will still be OBD0 but now its 2.0!
Old Apr 6, 2008 | 11:47 PM
b20rookie's Avatar
Default Re: <---1991 DA6 with b20 swap HELP!! (tnez)
yea thats what im on kompletlly b20b with all my stock ****..... oh and the boging out .... same here .... after a sekond she gets back together though
Old Apr 7, 2008 | 12:35 PM
408RSTeg's Avatar
your speed sensor is the problem just replace it and you should be good.
Old Apr 9, 2008 | 05:55 AM
jdmkid8383's Avatar
Default Re: <---1991 DA6 with b20 swap HELP!! (408RSTeg)
FIXED..IT WAS A VAC. LEAK IN THE BACK OF THE MANIFOLD A HOSE CAME OFF. TIME TO DO A 10 POINT CHECK AROUND THE DA..
Old Apr 9, 2008 | 06:59 AM
jhammond_82's Avatar
Reject Papi
well since you fixed that, you can now go to autozone and buy a 20 dollar filter. that thing looks like you ran over it and put it on your car. you can get a cai off ebay for like 25 bucks with shipping.
Old Apr 10, 2008 | 07:03 AM
b20rookie's Avatar
Default i have same problem
damn thats good you fixed it i gotta fix mine to just kant locate that damn vac......
1Vinny
Nov 10, 2012 05:12 PM
BlackAcura90
Jan 22, 2008 11:15 PM
dubs97integ
Sep 29, 2007 11:28 PM
Muglit
Dec 4, 2001 09:25 AM
