93 civic ex swap question
yes, i've searched and searched til I was blue in the face and can't seem to find a straight answer. I might be purchasing a 93 Civic EX to replace my '90 civic. The 90 has a LS out of a 00 teg. If i were to buy the 93, i'd like to put ls motor in it. I was wondering what mounts I need, and what wiring harness do I need? will the one from the 93 work for the 00LS motor? can someone please give me a straight answer?
well ull need a ecu and a conversion harness depending what ecu your runing iin the 90 .. obd0,1 or 2 i was use a conversion harness to obd 1 and youll need motor mounts id use after maket but if you gonna use oem use a gsr side mount most important you need a hydro tranny u didnt mention that part if you have one or not your 90 civic is cable transmission if your not going turbo use a b16 or gsr shorter gears = faster times its gonna cost some money though bout 500 and especialy a round here in mo might be hard to find unless you got a hook up i live in fort leanard wood currently and parts r a lot harder to find a round here then they are in socal
i'm running an obd1 ecu and have a boomslang jumper harness currently on the '90. I had planned on buying a new tranny for the 93. I do plan to turbo it eventually. so a tranny from a '00 teg ls isn't hard to come by for $200. but my question is, on a 93' what engine wiring harness do i need?
dkgoodrich
Jan 12, 2006 08:37 PM
user 996328629
Sep 21, 2005 11:24 AM
turbotime
Mar 15, 2004 08:55 PM
