can not get my car to start
Old Oct 17, 2007 | 11:33 AM
pane93civhb's Avatar
Default can not get my car to start
I have a 97 prelude sh standard trans I got it with blown turbo motor from auction I swapped in h22a but now I cant get spark or injector pulse I checked main relay changed distributor coils computer jumper harness nothing works I have power to coil and distributor I do not know what to do if anyone can help please thanks
Old Oct 17, 2007 | 02:13 PM
nonvteclude's Avatar
Default Re: can not get my car to start (pane93civhb)
are you sure you are getting power to the dist.? how have you tested for spark to the spark plugs? is the firing order correct?
Old Oct 17, 2007 | 03:35 PM
Default Re: can not get my car to start (nonvteclude)
I am positive I have power to the coil and distributor and I used a noid light to check the injectors but no pulse and yes the firing order is right but that does not matter if I cant even get spark
Old Oct 17, 2007 | 08:01 PM
JasonST's Avatar
Make sure all ur grounds are good and tight!
Old Oct 18, 2007 | 05:40 AM
mgags7's Avatar
Default Re: can not get my car to start (JasonST)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JasonST &raquo;</TD></TR><TR><TD CLASS="quote">Make sure all ur grounds are good and tight!</TD></TR></TABLE>
lol. you would know
If you have neither spark nor injector pulse, I'd check the main relay again. The fuel pump prime? The CEL light up for a sec when you turn it to II(on) or try cranking it?
Old Oct 18, 2007 | 09:20 AM
Default Re: can not get my car to start (mgags7)
I have fuel prime/pressure and all the grounds are tight and on so I do not know what to do now oh and I tried another main relay nothing though
98preludef20b
Jun 10, 2016 08:09 AM
dls_tech
Dec 16, 2010 12:24 PM
ITRICED
Mar 5, 2008 12:15 PM
candyteggy
Nov 10, 2006 02:32 PM
IWearMyKswiss
Aug 1, 2004 10:33 AM
