wipers wont work and when i have the fuse in the water motor is on at all times.
Old Oct 16, 2007 | 08:13 PM
mustang5.slow's Avatar
* B A N N E D *
Default wipers wont work and when i have the fuse in the water motor is on at all times.
what could be the problem the car wont turn on the wipers and when i put the 20amp fuse in, the water squrter is always on.
96 honda civic cx hatch.
Old Oct 16, 2007 | 08:54 PM
NOFX's Avatar
H-T White Ops
Try another switch.
Old Oct 16, 2007 | 08:56 PM
* B A N N E D *
Default Re: (NOFX)
would you be able to explain how that switch comes off and can you let me know if it is eazy to replace.?
Old Oct 16, 2007 | 09:16 PM
NOFX's Avatar
H-T White Ops
Default Re: (mustang5.slow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mustang5.slow &raquo;</TD></TR><TR><TD CLASS="quote">would you be able to explain how that switch comes off and can you let me know if it is eazy to replace.?</TD></TR></TABLE>
If I recall, there are two screws holding it in. You'll have to remove the steering column shroud to get to it. It will pull out once the screws are removed. I know mine stuck pretty well.
It's really easy to replace. It just sticks.
I don't know if this is your problem, but it sounds like it could be.
For the wipers it's basically the motor, linkage, plugs/wiring, switch (part of combo switch) and the intermittent control module on the back of the interior fuse panel.
Old Oct 16, 2007 | 09:38 PM
* B A N N E D *
Default Re: (NOFX)
on thanks I will do so.
BTW what does you name mean.??
Old Oct 16, 2007 | 09:48 PM
NOFX's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mustang5.slow &raquo;</TD></TR><TR><TD CLASS="quote">on thanks I will do so.
BTW what does you name mean.??</TD></TR></TABLE>
It's the name of a band.
http://en.wikipedia.org/wiki/NOFX
Dev1996
Aug 11, 2016 02:38 PM
dthug
Apr 28, 2008 07:08 AM
AJZerick
Mar 18, 2008 06:24 PM
go2sleep
Sep 2, 2007 10:08 AM
asianalbutt
Sep 15, 2005 06:24 PM
