JDM B16 SWAP MAP Sensor
The JDM B16 has a map sensor on the throttle body.
Also there is a firewall map sensor on the EG.
I'm using the JDM b16 engine wiring harness connected to a P30 ecu.
Using the stock chassis harness. I just extended the jdm b16 harness.
Anyways I'm getting a Code 5, MAP sensor. I don't know which one to use.
The firewall or the one that came on the throttle body.
i this might help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92ehatch »</TD></TR><TR><TD CLASS="quote">if you are switching from a motor with a firewall mount map sensor, to one with a tb map sensor then.
remove firewall mount map sensor.
take plug from firewall mount map sensor and plug it up to throttle body mount (it will reach)
done.</TD></TR></TABLE>
da9blk1
Jan 16, 2008 05:04 AM
Brian Hinson
13
Jun 24, 2006 04:05 PM
civichatch67
Sep 21, 2005 10:11 AM
