**NEED HELP** B18B1 with B16a2 Tranny into 96 EJ8, idling problems
Old Oct 16, 2007 | 07:30 PM
2tall's Avatar
Default **NEED HELP** B18B1 with B16a2 Tranny into 96 EJ8, idling problems
Ok, I swapped a 97 LS motor in, and it runs , but, it idles around 200 rpm, WHEN IT WANTS TO IDLE . Otherwise, it doesn't idle. Most of the time it doesn't stay running at all, and my check engine code is P1509, or P1409, can't remember , but it is the Idle Actuator Control Valve Failure code. Please help .
Old Oct 16, 2007 | 08:28 PM
2tall's Avatar
Default Re: **NEED HELP** B18B1 with B16a2 Tranny into 96 EJ8, idling problems (2tall)
before bed bump
Old Oct 17, 2007 | 08:42 AM
2tall's Avatar
morning bumpage
Old Oct 17, 2007 | 09:08 AM
pdiggitydogg's Avatar
1509 is your iacv...that would explain a lot...
Does it work at all? Have you cleaned it? Is it connected properly?
Old Oct 17, 2007 | 09:23 AM
2tall's Avatar
Default Re: (pdiggitydogg)
everything is connected. The IACV is the black sensor on the back of the intake manifold, correct?
Old Oct 17, 2007 | 02:53 PM
i.'s Avatar
i.
its on the back of the intake manifold, it has 2 coolant hoses going into it, and a 2 wire connector.
have a brand new in box oem iacv that i dont need and cant return. paid 290 for it, will sell it for 200 if you need one.
Old Oct 23, 2007 | 06:26 PM
2tall's Avatar
Default Re: (i.)
bottom one is what I have
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by i. &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
mustang5.slow
Oct 20, 2007 07:04 PM
BoostnEK6206
Oct 19, 2007 11:23 AM
89 pos
Oct 7, 2004 11:47 AM
Glocked1
12
Jan 22, 2004 08:13 PM
CrX1988Zc
Sep 16, 2002 04:26 PM
