Honda's 600rr
i don't think there can be a kit since there's no space inthe 07 tail for a tail light unless you custom make one.
I'm sure there are companies out there that make fender eliminator kits for the 07 rr that give it a new tail light, but i bet you it's still going to be below the exhaust.
Lot of people are making it happen with a bit of cutting the plastics, and sanding the light. When you take the tail piece off there is only a small piece of plastic thats blocking it from happening. Some dudes are cutting it out, building a bracket and putting the integrated one in. There is a company called " Clear Alternatives" if youve owned a bike you know this company, they make it now. It's shaved and ready to go, all you gotta do is cut the plastic under the fairing (very simple, very easy), then plug it in and your done, it also has the flashers built in.
Looks like this:
Hope this helps your question dude..
Looks like this:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by unusual71 »</TD></TR><TR><TD CLASS="quote">are there any better options for rear signals than the ones in the pic?
cause i've trailed guys with those kinds of signals and you can't see them for **** in the sun</TD></TR></TABLE>
This what I did.. made a custom bracket out of sheet metal.
(not my pic)
cut a slice on the bottom of the mudflap and lose it all under the brake light. Replace the rear signals with something smaller.
again not my pictures, because I couldnt find anything big to show mine, you get the idea though....the taillight is super bright and you can buy some small led signals for liek $25 somewhere to replace the big honkers.
(not my pic)
this guy tristan does a lot of work for the 600rr. he also does the 03-06 tail light mod for the 07. here's his site http://www.tripageled.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by getmadboy »</TD></TR><TR><TD CLASS="quote">this guy tristan does a lot of work for the 600rr. he also does the 03-06 tail light mod for the 07. here's his site http://www.tripageled.com</TD></TR></TABLE>
yea.....alot of people are running his kit for the 06 tailight conversion. good stuff
I just run the rizoma one
http://www.600rr.net/vb/showth...IZOMA
LED_crazy
Jul 1, 2012 02:48 PM
viciousef9
Jan 24, 2008 10:37 AM
