Motor Mount Q!!
Old Oct 16, 2007 | 09:56 AM
SilverWarrior's Avatar
Default Motor Mount Q!!
This is for a integra and the driver side motor mount blew/cracked. So I know I will need a new one..
My question is.. is it ok to replace just the Driver Side Motor Mount.. or is it better to replace all the Motor Mounts.
Modified by Lay's at 12:30 AM 11/5/2007
Old Oct 16, 2007 | 10:13 AM
Default Re: Motor Mount Q!! (Lay's)
Old Oct 16, 2007 | 10:30 AM
Malakai's Avatar
if the rest are fine, doing the one is ok.
Old Oct 16, 2007 | 01:20 PM
Default Re: (Malakai)
You sure? because the aftermarket mounts holds the car stiffer.. and other parts would be soft.. . so I wasnt sure.
Old Oct 16, 2007 | 02:03 PM
Malakai's Avatar
well u never said u were replacing with aftermarket. if so then replace all. if with oem just the one is fine.
Old Oct 16, 2007 | 03:41 PM
jdmcars.com's Avatar
I agree, I would recommend replacing the entire set up. However, with the week set of of the 96-00 style drivers side mount, I can see the need just for replacing only the drivers side mount.
Other questions, -what is done to the car? Even a stock set up and gain from upgrading the driver's side mount....the more you have done, the more you should lean towards replacing all three.
p.s. -PM'd you with some pricing as we do offer special pricing for h-t members.
Old Oct 17, 2007 | 12:25 AM
Default Re: (jdmcars.com)
Yea forgot to mention I am planning to replace it with an Aftermarket one........... so yes to replace all? or whats wrong with just replacing driver side mount with an aftermarket?
Old Oct 17, 2007 | 01:29 AM
suicide_shift's Avatar
* B A N N E D *
Default Re: (Lay's)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lay’s &raquo;</TD></TR><TR><TD CLASS="quote">Yea forgot to mention I am planning to replace it with an Aftermarket one........... so yes to replace all? or whats wrong with just replacing driver side mount with an aftermarket?</TD></TR></TABLE>
there are no negative sideffects of just replacing the one.........
but others recommend to do all of them..............
doesnt sound like you want to race it. doesnt sound like you drive it rough. you know that replacing all the mounts with hasport mounts or a simmiar mount will increase vibration in the car right? doesnt bother me (drive a civic with hybrid racing mounts) but it does bother alot of people as ell as exhausts, racing harnesses ETC
Old Oct 17, 2007 | 05:49 AM
b16a3delsol's Avatar
Default Re: (Lay's)
if going with aftermarket like hasport or avid then replace them all. but if its like advance brand aftermarket then just changing the one will be ok.
Old Oct 18, 2007 | 04:24 PM
Default Re: (b16a3delsol)
Yea.. like hasport , avid, innovative
so replace all ? or one will be ok.. still mix info.
And yes I do race at the track.
Old Oct 18, 2007 | 04:30 PM
ltrkstr2k's Avatar
Default Re: (Lay's)
if you race it then I would replace all of them. I would help in the long run
Old Oct 18, 2007 | 04:32 PM
Default Re: (ltrkstr2k)
not often though. mostly street.
Old Oct 27, 2007 | 06:11 PM
polything's Avatar
what kind of racing? have you consider HARDRACE MOUNT?
Old Oct 27, 2007 | 06:19 PM
Luserkid's Avatar
Default Re: (polything)
If your not going to do any racing and this is just a street car then just get the Hasport upper driver mount. It will stiffen the motor and is alot better then the liquid filled mount. I have seen that mount blow on 100% stock AUTO civics. If i ever got that year that would be the first thing to go and keep the rest stock.
Old Oct 28, 2007 | 09:27 PM
Default Re: (Luserkid)
what if I drag race at the track once a while? and if my car makes 200+ whp?
Old Oct 29, 2007 | 05:14 AM
Luserkid's Avatar
Default Re: (Lay's)
Whats once in a while and whats 200+whp? You do know 200+ means 200 - 100000000 whp right?
Old Oct 29, 2007 | 08:48 AM
oh i meant. how about the range of 200-225.. and once in a while is like every 3-4 months.
Si Speed
Oct 6, 2007 03:03 PM
Speed Infliction
Feb 2, 2007 03:29 PM
Liquidgsr
Nov 10, 2005 10:58 PM
TeGGY_LS
Nov 30, 2004 01:05 PM
TeGGY_LS
Nov 15, 2004 08:19 PM
