Firewall map sensor to a TB map sensor?
Old Oct 16, 2007 | 02:30 AM
da9blk1's Avatar
Default Firewall map sensor to a TB map sensor?
how and would that work? block of the hose from the firewall one...........run the hose too....?
anything?
Old Oct 16, 2007 | 02:41 AM
Duane_in_Japan's Avatar
Default Re: Firewall map sensor to a TB map sensor? (da9blk1)
go see integra
Old Oct 16, 2007 | 02:59 AM
92ehatch's Avatar
if you are switching from a motor with a firewall mount map sensor, to one with a tb map sensor then.
remove firewall mount map sensor.
take plug from firewall mount map sensor and plug it up to throttle body mount (it will reach)
done.
Old Oct 16, 2007 | 03:36 AM
VRD^sam's Avatar
Default Re: Firewall map sensor to a TB map sensor? (92ehatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92ehatch &raquo;</TD></TR><TR><TD CLASS="quote">if you are switching from a motor with a firewall mount map sensor, to one with a tb map sensor then.
done.</TD></TR></TABLE>
he said it
Old Jan 16, 2008 | 05:04 AM
Rease3's Avatar
Default Re: Firewall map sensor to a TB map sensor? (VRD^sam)
where do the vaccum lines go from the purge thing on the fire wall.?
H22EG'z
Sep 22, 2009 06:52 PM
dc2doi
Nov 9, 2007 12:16 PM
jmeyer99
Nov 6, 2006 07:07 PM
Hoosier Daddy
Mar 29, 2004 03:18 PM
killa_lude
Dec 28, 2003 07:09 AM
