Turbo on stock internals? ( My cars apart already, bad planning )
THE BACKGROUND:
I have a 2001 S2k with 124,000 miles, i'm getting the head rebuilt with Supertech springs retainers and Honda valves. Im also getting a port and polish and 3 angle valve job. I just got a compression test done and it was 197psi, 200psi, 185psi, 190psi , so im not sure about the bottom end.
MY PROBLEM:
With differential problems set aside, is it fine to turbo on stock internals? I was thinking about 6-7psi of boost. I drive this car to work everyday but not far at all. I'm not a really aggressive driver, but sometimes ill play on the freeway. It looks like most go Turbo.
Please Help!!
MY PROBLEM:
Please Help!!
You'll be fine. I'm currently running around 15psi on a daily driver with stock internals, only addition was a 3mm head-gasket. And I'm a pretty aggressive driver.
Munkyw3rkz.webs.com
3mm headgasket....
change out the oil/water pumps since the head is off... and boost away...
no need to port/polish the head its flows TONS from the factory...
block is forged as well already..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaKyle »</TD></TR><TR><TD CLASS="quote">i think im going to order a turbo right now....</TD></TR></TABLE>
Don't forget a proper engine management system and someone 'competent' that can tune it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Scott Howard »</TD></TR><TR><TD CLASS="quote">If 6-7 psi is too safe, what should I be looking at? 10?</TD></TR></TABLE>
It's not a matter of what psi is safe, it's a matter of how much power you personally want and the tuning. Tuning is key to all boosted projects.
why wouldn't you want to be safe? sacrifice reliability for big power and all this time and money you are spending will be a waste...especially for a daily vehicle
it's all in the tune.....
Munkyw3rkz.webs.com
9-10 psi with a untouched motor is the going # right now.... put a 3mm headgasket to drop the comp n u can boost more on 91oct
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by papa5murf »</TD></TR><TR><TD CLASS="quote"> @2:37p.m.
It's not a matter of what psi is safe, it's a matter of how much power you personally want and the tuning. Tuning is key to all boosted projects. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRAF-FITI »</TD></TR><TR><TD CLASS="quote"> @2:37p.m.
it's all in the tune.....</TD></TR></TABLE>
that was some weird ****
But mine came first. LOL.. Must be cause I'm a mod. Bahahaha.
Depends on your perspective....
I think anything less than 20 lbs is a waist of time, but thats just me..
lol
Crank dat boost and let er rip!!!
try knocking out my 630hp 100% stock block record while your at it
-James
lol
-James
^^^ yes lot of boost. at least were on the same page. would go after ur numbers but i just sleved my block..i guess that would be cheating if it was build. but il need a bigger turbo anyway.
