car won't start after a long drive
my car wont start after a long drive, when i try to start its not cranking, i know my battery is good coz its starts in the morning. i change my main relay already..
is it possible that the problem is my distributor? how would i know if my distributor is bad.. thanks
I doubt it's your dizzy because you don't need spark to crank it, Even if your main relay was bad it would still crank just would'nt start. It definetly sounds like a bad connection somewhere.
Are the battery terminals corroded? Loose? Is the air filter clogged/old?
Does the starter motor even make a sound when the key is turned on? could be dying, or bad connection.
