Custom downpipe ideas needed for very sharp 3" 90 degree bend
Old Oct 15, 2007 | 05:37 PM
eightvalver's Avatar
Default Custom downpipe ideas needed for very sharp 3" 90 degree bend
so far what i've found from pictures for a sharp 3" 90 degree elbow bend, 4 pie cuts can make the 90 degree bend,
but anybody have tips or other insights for a custom downpipe design for a very sharp 3" 90 degree elbow bend?
thanks
Old Oct 15, 2007 | 06:17 PM
EdsGTI's Avatar
Default Re: Custom downpipe ideas needed for very sharp 3" 90 degree bend (eightvalver)
i set my bandsaw to 4 deg and make pie cuts. The smaller you make the pieces, the tighter the bends.
Old Oct 15, 2007 | 06:40 PM
RCautoworks's Avatar
Metal Doughnut
Old Oct 15, 2007 | 07:42 PM
paulzy's Avatar
Default Re: Custom downpipe ideas needed for very sharp 3" 90 degree bend (RCautoworks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RCautoworks &raquo;</TD></TR><TR><TD CLASS="quote">Metal Doughnut</TD></TR></TABLE>
the best way. Most of everything I have seen with pie cuts have cracked at one time or another.
Old Oct 15, 2007 | 07:56 PM
Default Re: Custom downpipe ideas needed for very sharp 3" 90 degree bend (paulzy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paulzy &raquo;</TD></TR><TR><TD CLASS="quote">
the best way. Most of everything I have seen with pie cuts have cracked at one time or another.</TD></TR></TABLE>
Plus all the weld inside just limits the flow, not to mention the unconventional the bend.
Old Oct 15, 2007 | 08:09 PM
DaveF's Avatar
but its JDM
Old Oct 15, 2007 | 10:19 PM
MADMAX_zero's Avatar
Default Re: Custom downpipe ideas needed for very sharp 3" 90 degree bend (DaveF)
Here is a cool way to make a precise bend with pie cuts using a nice simple formula I developed.
http://www.homemadeturbo.com/f...55044
Old Oct 17, 2007 | 07:55 AM
hostiletx's Avatar
I used one of these, it is bent on a 3 inch CLR, it is a lot cheaper than buying a donut.
http://www.atpturbo.com/Mercha...e=PPB
Old Oct 17, 2007 | 10:10 AM
Lamchop0000's Avatar
Default Re: Custom downpipe ideas needed for very sharp 3" 90 degree bend (hostiletx)
^nnnnice
Old Oct 18, 2007 | 04:20 PM
Bev-Tech Inc.'s Avatar
what's the setup.. i'll get a pictre up tomorrow... for you
Old Oct 18, 2007 | 06:10 PM
paulzy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hostiletx &raquo;</TD></TR><TR><TD CLASS="quote">
http://www.atpturbo.com/Mercha...e=PPB</TD></TR></TABLE>
that's a very nice piece
Old Oct 18, 2007 | 09:21 PM
kordenbrock motorsports's Avatar
woolf aircraft also sells tight radius stuff. very fast shipping as well and great quality. they have oodles of mandrel bent items...best of luck!
Old Oct 20, 2007 | 05:37 PM
jonnybravo's Avatar
Default Re: Custom downpipe ideas needed for very sharp 3" 90 degree bend (Lamchop0000)
ATP Turbo
Old Oct 21, 2007 | 09:36 PM
That's deffinately the piece to use.... ATPTurbo.
or bev-tech.net
mister2racer
Mar 20, 2007 08:19 AM
E-Rok
Welding / Fabrication
13
Mar 22, 2005 08:26 AM
abmerop18
Mar 1, 2005 04:01 AM
accorracer
Feb 2, 2003 09:59 AM
