two questions about swapping b16 to b18c
Old Oct 15, 2007 | 04:02 PM
jrap1243's Avatar
Default two questions about swapping b16 to b18c
ok first question is i'm looking at a 96+ ITR swap so anyone know what the best place to buy it from would be? and two is since i already have a b series motor do i need to get the full swap that includes a tranny or can i get one thats just the motor?? i've been told swapping from one b series to the other is just plug n play type install. any info would be great! thanks for the help in advanced
Old Oct 15, 2007 | 04:06 PM
BlueIntegraBoy's Avatar
Default Re: two questions about swapping b16 to b18c (jrap1243)
You can use the B16 tranny, same as the 96 spec ITR without LSD. Depending what harness you have on the B16 motor it can be plug and play.
Old Oct 15, 2007 | 04:08 PM
jrap1243's Avatar
Default Re: two questions about swapping b16 to b18c (BlueIntegraBoy)
is not having the lsd going to make a huge difference??
Old Oct 15, 2007 | 04:12 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jrap1243 &raquo;</TD></TR><TR><TD CLASS="quote">is not having the lsd going to make a huge difference??</TD></TR></TABLE>
Depends on how you use your car. There are aftermarket LSDs better than the factory one that you can add later on.
Old Oct 15, 2007 | 04:17 PM
posHonda's Avatar
Just get the motor if I were you. The b16 tranny mated to it will still work great even though it doesnt have LSD like the ITR tranny.
Just grab a quaife LSD later on if you want one.
Old Oct 15, 2007 | 04:19 PM
jrap1243's Avatar
Default Re: (iVteC_PoWeR)
alright so then where would be the best place to pick one up at. obviously the least expensive would be best. i know pswdjdm is one of the cheapest ive seen but i dont know if theres anywhere else. if anyone can let me know that would be great.
Old Oct 15, 2007 | 04:20 PM
Default Re: (jrap1243)
hmotorsonline is the best place to get it imo, heard bad things about pjdms engines.
Alexpbnj
11
Sep 21, 2010 12:27 PM
em1_sir
Feb 22, 2008 11:37 AM
hondaboyB18C1
Oct 22, 2007 03:12 PM
dannis.
Mar 21, 2007 02:31 PM
92-Teal-Hatch-B16
Sep 8, 2006 03:26 PM
