what do you think this set will do help
Old Oct 15, 2007 | 03:20 PM
lsvtecdz's Avatar
Default what do you think this set will do help
so i have
Bore 20 over ls b18b bottem with stock do have inline pro block guard
head b16 has stock crower valves ti. ret. cower springs
rev hard cast manifold
t3-60 ar.70
3 inch turbo back
type r int. man.with stock thrott.
msd ign set up
2.25 inter piping
hondata s200
what do you think is 450 to 500 crazy thoughts on race gas
help we out
Old Oct 19, 2007 | 06:07 PM
lsvtecdz's Avatar
Default Re: what do you think this set will do help (lsvtecdz)
anyone if you need more info let me know just don't want to get hopes to high
Old Oct 19, 2007 | 06:56 PM
Schister66's Avatar
Man U FTW
bigger intercooler piping would probably help those peak power numbers...500whp is going to take a lot of air and 2.25" probably wont cut it. In order to make high hp, you need to squeeze as much efficiency out of a setup as possible...the Drag manifold isnt going to help that cause either. Not to mention with that turbo and a 38mm wastegate, you might have boost creep issues
94-integra-ls
Mar 22, 2008 10:07 PM
lsvtechatch92
Welding / Fabrication
Nov 5, 2007 06:43 AM
coreyhayman
Oct 18, 2007 09:12 PM
ITR9788
Jul 30, 2003 01:30 PM
pub
Jul 27, 2002 09:38 PM
