what do you think this set will do help
so i have
Bore 20 over ls b18b bottem with stock do have inline pro block guard
head b16 has stock crower valves ti. ret. cower springs
rev hard cast manifold
t3-60 ar.70
3 inch turbo back
type r int. man.with stock thrott.
msd ign set up
2.25 inter piping
hondata s200
what do you think is 450 to 500 crazy thoughts on race gas
help we out
t3-60 ar.70
3 inch turbo back
msd ign set up
2.25 inter piping
hondata s200
help we out
bigger intercooler piping would probably help those peak power numbers...500whp is going to take a lot of air and 2.25" probably wont cut it. In order to make high hp, you need to squeeze as much efficiency out of a setup as possible...the Drag manifold isnt going to help that cause either. Not to mention with that turbo and a 38mm wastegate, you might have boost creep issues
