motor mounts vs inserts
Old Oct 15, 2007 | 02:36 PM
Lsweez's Avatar
Default motor mounts vs inserts
which is the better of the two, motor mounts or inserts..and does anyone on here have inserts if so how do they performane and are they worth it?
Old Oct 15, 2007 | 03:32 PM
Dartanian's Avatar
Default Re: motor mounts vs inserts (Lsweez)
I am using the inserts in the front passenger side torque mount and rear mount with the front driver side torque mount taken out due to turbo clearance issues. It performs well but I am looking to step up to a set of full poly mounts for the three major mounts.
Old Oct 15, 2007 | 03:54 PM
Lsweez's Avatar
Default Re: motor mounts vs inserts (Dartanian)
was the instaltaion for the inserts hard?
Old Oct 15, 2007 | 04:10 PM
Dartanian's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lsweez &raquo;</TD></TR><TR><TD CLASS="quote">was the instaltaion for the inserts hard?</TD></TR></TABLE>
It wasn't that hard but it did take a good amount of effort. The front two took me about an hour each and the rear took about two hours. The rear mount is a total pain in the *** to get to if you still have a stock intake manifold.
Old Oct 15, 2007 | 04:11 PM
wernhersey's Avatar
I used inserts in my DA and hated them, they didn't fit well for my car and they didn't give the support I was looking for. They have been the trick for some people but from my own experience I hated them. I ended up using innovative mounts. There is my 2 cents
Old Oct 15, 2007 | 04:21 PM
dizzzane's Avatar
Curious, why would you replace the mounts with inserts unless the motor had to come out or a mount was broken? Sounds like a lot of effort for minimal compensation?
Old Oct 15, 2007 | 04:25 PM
jonshonda's Avatar
Community Builder
The stock mounts will wear with time, and decrease in strength and allow the engine to move around. Poly mounts/inserts will reduce engine movement helping to put the power where in needs to go, and help to decrease wheel hop
Old Oct 15, 2007 | 04:33 PM
B.J.'s Avatar
Motor mount look cool but I know a kid with a vary fast all motor ls v-tec with inserts and they work great.
Old Oct 15, 2007 | 04:48 PM
Dartanian's Avatar
Default Re: motor mounts vs inserts (dizzzane)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dizzzane &raquo;</TD></TR><TR><TD CLASS="quote">Curious, why would you replace the mounts with inserts unless the motor had to come out or a mount was broken? Sounds like a lot of effort for minimal compensation?</TD></TR></TABLE>
The difference is pretty noticeable.
Old Oct 25, 2007 | 09:23 AM
all-mtr-teg's Avatar
How much more vibration do you get?
Old Oct 25, 2007 | 11:37 AM
NAmodified's Avatar
Default Re: motor mounts vs inserts (all-mtr-teg)
inserts.... are great... prothane and energy are 2 companies... I have all 5 mounts on my dc2. I have the lower torques aand the 2 upper mounts. It handles pretty good. It feels stiff... which is what I want.
IMO performance motor mounts are a waste of money. You can get inserts for a fraction of the cost of performance mounts.
Old Oct 25, 2007 | 03:24 PM
PACT man's Avatar
Default Re: motor mounts vs inserts (NAmodified)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAmodified &raquo;</TD></TR><TR><TD CLASS="quote">inserts.... are great... prothane and energy are 2 companies... I have all 5 mounts on my dc2. I have the lower torques aand the 2 upper mounts. It handles pretty good. It feels stiff... which is what I want.
IMO performance motor mounts are a waste of money. You can get inserts for a fraction of the cost of performance mounts. </TD></TR></TABLE>
I agree with him. Yes the full mounts are nice, but for the price of the inserts you can't beat that. I had them on my old DA and they make a huge difference stiffening thigns up. I was skeptical about them at first too becuase I thoguth they would be loose in the mount and not do much, but they do use very close clearances and take up all the extra space that makes your motor move around. My old DA had the ES(brand I would recommend) inserts in the front and rear mounts along with an Innovative auto to manual mount for the tranny.
Old Oct 27, 2007 | 03:29 PM
wernhersey's Avatar
Sorry maybe I wrote that wrong. What I meant was that I had worn out stock mounts and it ripped my tranny apart so I tried the inserts. Those also did not work for me so I finally bought real mounts.
Old Oct 27, 2007 | 03:33 PM
wernhersey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg &raquo;</TD></TR><TR><TD CLASS="quote">How much more vibration do you get?</TD></TR></TABLE>
The vibration is awsome! When its about -20F out and I fire up the teg it vibrates like a *****. It rattles everything and anything. But In the summer @ about 70F or so its not to bad. And also I have a DA these babys rattle no matter what. If you have a DC you may not have as many rattles.
Old Oct 27, 2007 | 03:44 PM
94 IntegraLS's Avatar
Default Re: motor mounts vs inserts (wernhersey)
Im looking into getting some of these since im gonna be boosting my DB7 next year and im just wondering since ive never installed inserts... do you have to remove the motor mount completely? or is there an easier way to install them?
Old Oct 27, 2007 | 06:23 PM
suzawa94's Avatar
Default Re: motor mounts vs inserts (94 IntegraLS)
Old Oct 29, 2007 | 07:08 PM
suzawa94's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lsweez &raquo;</TD></TR><TR><TD CLASS="quote">which is the better of the two, motor mounts or inserts..and does anyone on here have inserts if so how do they performane and are they worth it?</TD></TR></TABLE>
just recieved my ES insert kit today. i'll keep u posted after i install it this weekend
Old Oct 29, 2007 | 07:28 PM
401tuner's Avatar
Default Re: motor mounts vs inserts (suzawa94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suzawa94 &raquo;</TD></TR><TR><TD CLASS="quote">
please do
Old Oct 29, 2007 | 08:21 PM
vietnamezerice's Avatar
Default Re: motor mounts vs inserts (401tuner)
what do you guys think about just filling the mounts with a tube of polyurathane?
Old Oct 29, 2007 | 08:41 PM
LemonsEH2's Avatar
I installed Energy Bushing polyurethane mounts on my civic. It would be a lot easier to remove the mount completely, then install the inserts.
the only side that took some effort is the driver side ( you have to cut the mount and ring out completely) and pressing the polyurethane in with out a press while the the transmission mount and rear are simply "add on" to the stock bushings.
Old Nov 5, 2007 | 06:21 PM
suzawa94's Avatar
Default Re: motor mounts vs inserts (LemonsEH2)
just put in the es inserts this past weekend. yeah, the rear was a bitch and a half, but we got it done.
vibration is not that bad at all. i had prothane inserts before and to me they were unbearable. besides, my rear mount was fucked to say the least (came out in 2 pieces). feels a whole lot "sturdier" i guess. kinda hard to explain though. compared to before (broken, worn stock mounts) doesn't seem to bog as much with the a/c on. the most vibration i feel is from a complete stop coming out of first. just a slight dash shake. once it gets going you kinda forget about the vibration. very minimal while driving. but yeah, good stuff can't beat if for 40 bucks
Old Nov 5, 2007 | 08:08 PM
SIC_jdm_da9's Avatar
just go to the es website and go to there ebay and they the DIY inserts for all hondas and acuras....
Old Nov 6, 2007 | 11:22 AM
Tim2179's Avatar
eight equals equals equals D
Community Builder
Loved
Are you stock motor mounts worn out?
I used the ES polyurethane inserts for 2 years. I got tired of all the rattles in my interior at all RPM (its REAAAAALLY BAD). I took them out a month ago and it feels like I'm driving around in a Caddy or something - super quiet!
So, if you plan to race your car a lot and don't mind the rattles 24/7, then ya, the inserts are fine.
But if you plan on driving it on the street, I wouldn't bother with the inserts.
acmoc
Mar 29, 2017 05:36 PM
Boner_Ben
May 29, 2007 03:21 PM
Spectrum24x
Jul 6, 2005 10:34 PM
Maengelito
16
Dec 5, 2004 07:07 AM
ragejed
May 18, 2002 06:56 PM
