signal lights---bright light---in gauge cluster---affecting heater gauge needle?!?!?!?!
Old Jun 20, 2002 | 09:50 AM
JediPimpCrx's Avatar
Default signal lights---bright light---in gauge cluster---affecting heater gauge needle?!?!?!?!
Pretty much the title, I start the car and the left turning signal and the brights light (blue) are on but very dim. If I use the left turning signal the engine temp gauge moves to the beat. If I use the brights then the needle on the gauge continuesly goes to the top at a fairly fast steady pace.
I think that it has somthing to do with the electrical but i have no Idea where to look.
Seccondly how to I find out if my radiator fan is busted. It seems not to work but all the wiring and fuses seem fine.
I drive a 88 CRX with a B16A transplant....... if anyone could help it would be great.
Old Jun 20, 2002 | 09:53 AM
SuperCivic's Avatar
Default Re: signal lights---bright light---in gauge cluster---affecting heater gauge needle?!?!?!?! (JediPim
did you recently switch gauge clusters? when i put a 90 cluster in my 89 BEFORE rewiring, i had similar results.
if not, sounds like you got some wires crossed up
[Modified by SuperCivic, 1:54 PM 6/20/2002]
Old Jun 20, 2002 | 10:05 AM
No I havn't done a gauge cluster swap yet just the B16 transplant recently
chock289
Honda Civic (2001 - 2005)
Sep 10, 2007 09:48 PM
Boofster
Dec 6, 2004 03:18 PM
Mrfeee1
Oct 7, 2004 08:40 AM
sung
Aug 10, 2004 12:03 PM
