Power Door Locks Not Working.... HELP!!
Old Oct 15, 2007 | 07:45 AM
bassysingh's Avatar
Default Power Door Locks Not Working.... HELP!!
I have both a 96 & a 98 Civic, both Ex's and both power door locks are not working. The 98 I've had for about 2 years and they haven't worked from when i got them but when i had the alarm installed they checked all components out and said that it's getting power and giving power and suggested that it may be the Power Lock relay/module (can't remember exactly which one). I'm thinking that since the 96 is having the same problem (previous owner said that it once worked and once day stopped) that it may be caused by the same thing. I'm not sure where to find the module/realy. In the repair manual it says that it's behind the cluster but is very vague.... Has anybody had this problem before? And if so, can somebody help me remedy this? Seems senseless to have an EX without power locks....
Old Oct 17, 2007 | 06:30 PM
bassysingh's Avatar
so nobody has run into this problem at all?
Old Oct 19, 2007 | 04:22 PM
bassysingh's Avatar
help!!
Old Oct 21, 2007 | 03:29 PM
niCastro's Avatar
Default Re: (bassysingh)
yeah my remote doesn't work anymore either (i have put new batteries in it and the red light turns on when i press a buttong) but my driver's side door is a little scetch too. I have to hold the handle out while pressing the lock switch to lock the doors.
Old Oct 23, 2007 | 09:34 AM
bassysingh's Avatar
well at least you have something going, i have nothing at all. not if i hit the switch or if i lock it manually, i'll still have to lock the other side manually. somebody's gotta know something
Old Oct 23, 2007 | 11:04 AM
monicle's Avatar
the lcok control box is the relay. they are 1 in the same. 96-98 it will be a blue box inside the door. grounds and fuses ok?
Old Oct 23, 2007 | 03:58 PM
bassysingh's Avatar
yeah, all grounds and fuses check out as good. how do i determine if the lock control box is bad?
Old Oct 24, 2007 | 06:15 AM
monicle's Avatar
if power tests ok going into the control box and contintuity on the ground wire is good, but you arent getting power back out of the box to the lock actuator leads, then the box is bad.
test for power on white/green
and ground continuity on the black wire.
if those are good but you dont get power on white/red blue/red or yellow/red while working the switch then youre box is bad
Old Oct 24, 2007 | 02:02 PM
bassysingh's Avatar
thanks a lot man, i'll let you know
Old Oct 24, 2007 | 02:19 PM
ukdmegg5's Avatar
Had the same problem with my old hatch
seatown206
Honda Civic (2001 - 2005)
Mar 28, 2010 06:51 PM
litoekneeil
Mar 15, 2010 09:14 AM
2DoorBandit
Dec 14, 2007 10:45 AM
BSIXTEENSOFAST
Acura TL, RL & ZDX
Aug 8, 2005 07:46 AM
HondaHemi
May 27, 2005 03:48 PM
