Belt slipping?
Old Oct 15, 2007 | 07:39 AM
scottblade's Avatar
Default Belt slipping?
I just got a 1997 SH and when I shift from first to second or second to third under 3000 rpms it seems to take a second to grab like the belts are slipping. Any suggestions.
Old Oct 15, 2007 | 09:08 AM
Hawkze_2.3's Avatar
Default Re: Belt slipping? (scottblade)
What belts are you talking about? You think your alternator or your power steering or your AC has a delay when you shift?
Old Oct 15, 2007 | 09:22 AM
117's Avatar
117
CVT maybe?
Old Oct 15, 2007 | 09:23 AM
Hawkze_2.3's Avatar
Default Re: (117)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 117 &raquo;</TD></TR><TR><TD CLASS="quote">CVT maybe? </TD></TR></TABLE>
Of course!
Old Oct 16, 2007 | 08:06 AM
scottblade's Avatar
Default Re: (Hawkze_2.3)
I dont know, maybe it is my clutch. It is a manual transmission, but id I am driving conservatively and I shift from just say first to second, once I am in second gear the car is kind of sluggish until about 3,000 rpms and you can feel the car kind of kick in. I didnt know if it is the clutch wearing out or some kind of belt or something slipping in the engine. Thanks.
Old Oct 16, 2007 | 08:12 AM
Ralleh's Avatar
Scan the ecu for codes.
Old Oct 16, 2007 | 08:14 AM
ludenoob99's Avatar
Default Re: (scottblade)
ok well if you feel the car rev up but not accelerate then your clutch is slipping. the only belts that could be slipping on your motor would be the ones driving the ac compressor and the alternator so they wouldn't effect the feel of the car. is the car just kinda bogging down and not really accelerating well under 3000rpm? or is it reving up but not really grabbing?
Old Oct 16, 2007 | 08:20 AM
scottblade's Avatar
Default Re: (ludenoob99)
Its kinda bogging down, its is def. not the clutch slipping. I had that problem enough in my Cobalt SS I had.
Old Oct 16, 2007 | 08:41 AM
boostedh22lude1's Avatar
its the clutch. put it in 5th at 20-mph and see if it revs while under load.
Old Oct 16, 2007 | 08:43 AM
scottblade's Avatar
Default Re: (boostedh22lude1)
Ok, I will try it later when I have a chance to.
Old Oct 16, 2007 | 10:29 AM
scottblade's Avatar
Ok so if it is my clutch I am going to go ahead and get the Exedy stage 1 and fidanza fly wheel done at my shop that will cost about $350. Now, my transmission grinds a little going in to 5th gear, right now I doble clutch and it does not grind. Should I go ahead and have them rebuild or take a look at the transmission since they will be down there taking apart everything anyway?
Old Oct 16, 2007 | 12:05 PM
ludenoob99's Avatar
grind on 5th gear upshift is a very common problem with the fifth gen preludes. the entire trans dosent need to be rebuilt, it just on little piece that you can replace. i forget what exactly its called but i remember it only costs like 80 bucks to fix. i have it sometimes too but i just ignore it, it still works so i'm not gonna bother pulling out the trans to fix it.
Old Oct 16, 2007 | 12:09 PM
Ralleh's Avatar
97s have a defective shift fork that causes a lot of them (including mine) to grind into 5th.
Old Oct 17, 2007 | 11:43 AM
scottblade's Avatar
Default Re: (Ralleh)
Well that would be cool to be able to get it fixed just because. But it is not my clutch, I put it in to 5th gear and drive from 20 mph up to 40 and it never slipped. I can dump the clutch and it wont slip at all....
Old Oct 17, 2007 | 01:08 PM
DCxMagus's Avatar
well you do have a stock prelude. When I had this problem it was my distrubitor, cap, rotor, wires and plugs. Changed those all out and problem went away.
When was the last time you a maintenace was done on the car ignition parts?
Stock, the preludes don't have that much power below 3K but if you have warn out ignition parts you'll feel it even more.
Old Oct 17, 2007 | 02:06 PM
shadow29485's Avatar
CVT?? Sounds familiar....??
Old Oct 17, 2007 | 02:09 PM
Default Re: (shadow29485)
How about a refresher guys? What's the"CVT" again?
Thanks....
Old Oct 17, 2007 | 02:15 PM
DCxMagus's Avatar
Continuous variable transmission
or something to that effect, it's a type of automatic transmission that has an infinite number of gears so that you don't feel the shifts, problem is if you are putting down any type of noticeable power over stock they don't tend to like that. I know they were used in the saturn ION's first gen coupes if you got auto tranny you got a CVT, the sedans used a stronger 5spd auto from misin I believe.
Preludes don't have CVT's they were just joking around.
Old Oct 17, 2007 | 09:48 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shadow29485 &raquo;</TD></TR><TR><TD CLASS="quote"> How about a refresher guys? What's the"CVT" again?
Thanks....</TD></TR></TABLE>
http://auto.howstuffworks.com/cvt.htm
Yeah, continuously variable transmission.
It's a transmission with no gears, only 2 pulleys; one of which can vary the size of the section that the belt rides on effectively changing the gearing infinately...well almost.
Old Oct 18, 2007 | 05:07 AM
scottblade's Avatar
Yea I have a stock SH...and I am not sure when those were serviced last, ive only had the car for 5 days. One of the first things i normally do is replace spark plugs and spark plug wires to the really good wires immediately. Come to think of it, my old Accord had the same problem and it was just the spark plugs and wires....I will replace those today and see if that works..thanks!
Old Oct 19, 2007 | 07:43 AM
scottblade's Avatar
Well I replaced the spark plugs with the NGK platinum, and I added some Restore to my oil, but it is still doing it. I sprayed some water on the wires at night with the engine running but didnt say any sparks. So, I will buy some new wires from my friend who works at Napa on Monday so I can get them cheap and see if that helps. Any other ideas of what it might be?
Old Oct 19, 2007 | 01:57 PM
ludenoob99's Avatar
dont spray water on your spark plug wires! it will cuse moisture to get traped under the boot an cause corrosion. to test for spark you just have to stick it near a ground with a screwdriver in the end
Old Oct 19, 2007 | 05:27 PM
...OK. I was assuming that the tranny was a manual.
DSRxGOOMPA
Jul 19, 2007 02:20 AM
Libertariat
May 3, 2007 12:48 PM
ylfotevoli
Apr 11, 2007 02:33 PM
Libertariat
Sep 8, 2006 09:56 AM
Hatch It
May 3, 2005 10:01 PM
