no noobs, surge and ecu
Old Oct 15, 2007 | 05:09 AM
jdm91CrxSi's Avatar
Default no noobs, surge and ecu
this saturday i swapped my 99' y7 into my 94 ej2. i changed the alternator, throttlebody, and distributor, oh and the y8 manifold . I used my stock obd1 harness and Im throwing No CEL light (damn im good) but for some reason it is Surging. in the back of my mind it's my Idle Air Control valve. my timing is advaced. (distributor forward) which is giving it a nice idle and good pull, do you think its the ecu that can be doing this?. also what ecu should i run for this y7, im thinking about an obd1 ls ecu would do fine? ? ?
appreciate it.
Old Oct 15, 2007 | 06:09 AM
jdm91CrxSi's Avatar
Default Re: no noobs, surge and ecu (jdm91CrxSi)
views w/ no info
Old Oct 15, 2007 | 06:14 AM
97Ej6mike's Avatar
Have you let the car fully warm up yet? It may FITv related (if you have that hooked up, some people bypass it). It basically controls Idle for cold starts.
Old Oct 15, 2007 | 06:34 AM
jdm91CrxSi's Avatar
Default Re: (97Ej6mike)
actually when i first start it for about a minuite it will run fine. then it starts surging. and whats weird is when i cut on my lights its more of a longer surge instead of short drops
Old Oct 15, 2007 | 06:40 AM
ShortyzKustomz's Avatar
I'd def check IACV then, The IACV senses loads like a/c compressor and alternator pull, when my IACV went, when I would hit my a/c on the surges would get longer as well
tallkan
Engine Management and Tuning
12
Jun 7, 2009 11:48 AM
kcD!lla
Mar 4, 2009 11:11 AM
mattm868
Sep 7, 2007 06:41 PM
ev0luti0n
Sep 27, 2005 07:42 AM
whitesohcs
Jun 30, 2004 03:03 PM
