Car shuts off immediately after turning it on, anyone have this problem?
1993 LS
It only does it first thing in the morning when it's really cold or if I'm doing a bunch of short trips (go somewhere run inside for 5 mins, go outside and turn it on it'll usually take 2-3 tries to get it to stay on)
Anyone else ever have that problem?
Do you have the hold the key and it'll keep running?
Could be the electrical portion of the ignition switch.
Then again more likely the Main relay.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by u n v kenny »</TD></TR><TR><TD CLASS="quote">Do you have the hold the key and it'll keep running?
Then again more likely the Main relay.</TD></TR></TABLE>usually if I just hold down the gas it'll stay on
I had a b16 hatch for a while that would do the same thing but it wouldn't turn back on right away like this one will. It would also only do it very rarely... this one does it almost every time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator »</TD></TR><TR><TD CLASS="quote">Set your base idle and clean the IACV and FITV.</TD></TR></TABLE>The base idle is fine... it idles spot on at 750 with no deviation, idles like a new car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90gs »</TD></TR><TR><TD CLASS="quote">The base idle is fine... it idles spot on at 750 with no deviation, idles like a new car.</TD></TR></TABLE>
The base idle is not 750 RPM. It is usually 450+-50 RPM. This is set by disconnecting the IACV and adjusting the idle set screw on the throttle body. If the base idle is too low and the IACV is having problems, the car can stall.
See my signature for a manual for your car.
See my signature for a manual for your car.</TD></TR></TABLE>
450, really?
This is my 4th integra and they've all idled at 700+- 50
Well lets say that the idle is 750... you said that if it's too low that it can stall, if anything its too high.
450, really?
450, really?
Well lets say that the idle is 750... you said that if it's too low that it can stall, if anything its too high.</TD></TR></TABLE>
When you reconnect the IACV, it adds more air to bring the idle to 750 RPM. Without the IACV connected on a wam engine, the idle should be 450 (check for your car's specifics in a manual).
450, really?
When you reconnect the IACV, it adds more air to bring the idle to 750 RPM. Without the IACV connected on a wam engine, the idle should be 450 (check for your car's specifics in a manual).</TD></TR></TABLE>I realize that... but I don't really care if it idles at 750 or at 450, I just want it to stay on when I turn it on for the first time.
I noticed that if I hold the gas pedal in just slightly while I'm turning it on it will stay on.
91hob20hb
Jul 17, 2004 11:16 AM
