starting problem, key clinder maybe?
Old Nov 10, 2005 | 02:01 PM
CW96's Avatar
Default starting problem, key clinder maybe?
When I turn the key to its final position, it starts, but then as soon as I let go, the key pops back and the car shuts off. Now is this a problem with JUST the key cylinder or something else?
My guess is that it might be the only problem, which is not an issue since I had new ones to replace all around. PLEASE SOMEONE HELP ME.
Old Nov 10, 2005 | 02:26 PM
thelate1's Avatar
Default Re: starting problem, key clinder maybe? (CW96)
yeah, try replacing the ignition switch. i believe it's around $60 from acura.
Old Nov 10, 2005 | 06:17 PM
CW96's Avatar
Default Re: starting problem, key clinder maybe? (thelate1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thelate1 &raquo;</TD></TR><TR><TD CLASS="quote">yeah, try replacing the ignition switch. i believe it's around $60 from acura.</TD></TR></TABLE>
can someone help me find the part number or something or a diagram, I am not trying to spend too much money on this besides the parts because this is just a daily driver.
Old Nov 10, 2005 | 08:06 PM
Backk InTheDA's Avatar
I hate everything
My car does the same thing actually. It used to start up and die, but that was cause to a faulty main relay, I replaced that though, and it does that every now and then.
Is this a G3 or G2?
Old Nov 11, 2005 | 01:55 PM
CW96's Avatar
Default Re: starting problem, key clinder maybe? (BuilttB18C5)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BuilttB18C5 &raquo;</TD></TR><TR><TD CLASS="quote">My car does the same thing actually. It used to start up and die, but that was cause to a faulty main relay, I replaced that though, and it does that every now and then.
Is this a G3 or G2?</TD></TR></TABLE>
1996 g3 i guess.
Old Nov 11, 2005 | 08:25 PM
b-power's Avatar
definately
Old Nov 11, 2005 | 09:09 PM
renegadez7o7's Avatar
From: flatlandz CA 7o7 But Now In Phoenix AZ, AZ and CA, usa
had problem last week they're right ignition switch it is
Old Nov 12, 2005 | 07:05 AM
CW96's Avatar
Default Re: (renegadez7o7)
Thank you guys, I really appriciate it
GO-FIGHT-KILL
May 22, 2007 06:34 PM
Skipper75
22
Mar 8, 2007 07:02 PM
allsho
Feb 10, 2007 05:05 PM
deviant94ex
Feb 17, 2004 09:45 AM
