b16a map sensor #3 code, can't get it to go away.
hey guys i have a b16a obd1 sir motor in my integra, i just recently got it back into the car and everything runs fine, except for the fact it's throwing a map code #3 which says something along the lines of "wiring issue, unplugged, blah blah" so it's electrical, not mechanical. overall the car runs fine, the map sensor seems to be about 90% working but it still runs rich and obviously i can't see a stitch of vtec until this code is resolved.
I have checked voltage on the wires coming in to the map and it only showed 4.61 when the chilton manual says it should be 5 volts but doesn't tell what to do in that case.
also i tried test for continuity in the line, but i kinda forgot how either way to of the lines where showing an ohm reading and idk if they are supposed i have nothing to compare against.
also i have tried reseting the ecu multiple times and the check engine comes back on immediately and tps sensor is fine and tight.
any thoughts or help are appreciated.
SilverShot
Jan 6, 2009 12:35 PM
philosofy1
10
Aug 26, 2006 07:35 AM
JibOnALib
12
Sep 14, 2005 11:51 AM
