B20
The CRV also came with either the P8R head or P75 head in it's 96-98 model years. The P8R head is a completely different casting than P75 heads which were used on all other B20's. This head came with 84mm combustion chambers and 33mm vtec sized intake valves.
https://honda-tech.com/zero...67903
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyte-S »</TD></TR><TR><TD CLASS="quote">Whats the benefits of swapping a B20 in, instead of say a B18?</TD></TR></TABLE>
i dont think is a benefit between b20b vs b18b, unless you have the b20z. i think both block are good, but the b18b will have the slight upper hand due to revs.
b20b - redline 6200
b18b - redline 7100/7200 (please correct me if i am wrong)
so at this point...i would get what ever is cheaper
b20b - redline 6200
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by em1_fox »</TD></TR><TR><TD CLASS="quote">y dont u just get a b20 block and slap on a vtec head...</TD></TR></TABLE>
dO you even know what that requires? It's often more trouble and $$$$ than what's it worth.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMFreak »</TD></TR><TR><TD CLASS="quote">
b20b - redline 6200
x2, revving is a huge factor in those to.
b20b - redline 6200
Im not sure if this is true, but i heard the b20 swap was more if you plan on boosting it. My friend has a fully built b20 swap in his em1 and my type s eats it up by a couple cars.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyte-S »</TD></TR><TR><TD CLASS="quote">Im not sure if this is true, but i heard the b20 swap was more if you plan on boosting it. My friend has a fully built b20 swap in his em1 and my type s eats it up by a couple cars.</TD></TR></TABLE>
this is incorrect. the b20b does have a low compression (8.8) which any turbo kit setup would love, but the cylinder walls are prone to crack under stock boost (from what i read on H-T over a short time frame). i have not seen the inside of my b20 block yet, but it has a cast iron - 1 piece design sleeve, so it tend to crack under pressure and Heavy road course driving.
