B20
Old 10-13-2007, 11:55 PM
Coolero's Avatar
Default B20
heard about a b20 head called ... p8r head it suppossable has vtec values and i was wondering if there's anything like that or should i go kick someone ???
Old 10-14-2007, 02:22 AM
JDMFreak's Avatar
Default Re: B20 (Coolero)
The CRV also came with either the P8R head or P75 head in it's 96-98 model years. The P8R head is a completely different casting than P75 heads which were used on all other B20's. This head came with 84mm combustion chambers and 33mm vtec sized intake valves.
https://honda-tech.com/zero...67903
Old 10-14-2007, 03:01 AM
Tyte-S's Avatar
Default Re: B20 (JDMFreak)
Whats the benefits of swapping a B20 in, instead of say a B18?
Old 10-14-2007, 07:21 AM
JDMFreak's Avatar
Default Re: B20 (Tyte-S)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyte-S &raquo;</TD></TR><TR><TD CLASS="quote">Whats the benefits of swapping a B20 in, instead of say a B18?</TD></TR></TABLE>
i dont think is a benefit between b20b vs b18b, unless you have the b20z. i think both block are good, but the b18b will have the slight upper hand due to revs.
b20b - redline 6200
b18b - redline 7100/7200 (please correct me if i am wrong)
so at this point...i would get what ever is cheaper
Old 10-14-2007, 07:54 AM
em1_fox's Avatar
y dont u just get a b20 block and slap on a vtec head...
Old 10-14-2007, 08:55 AM
Boost_V's Avatar
Default Re: B20 (em1_fox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by em1_fox &raquo;</TD></TR><TR><TD CLASS="quote">y dont u just get a b20 block and slap on a vtec head...</TD></TR></TABLE>
dO you even know what that requires? It's often more trouble and $$$$ than what's it worth.
Old 10-14-2007, 09:07 AM
96 EX's Avatar
Default Re: B20 (Boost_V)
or you could go to the all motor forum and read "how to build a reliable lsvtec"
which is very detailed and almost guarenteed to stay together. But its up to you.
Old 10-14-2007, 09:10 AM
* B A N N E D *
CirCus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMFreak &raquo;</TD></TR><TR><TD CLASS="quote">
b20b - redline 6200
x2, revving is a huge factor in those to.
Old 10-14-2007, 10:06 AM
Tyte-S's Avatar
Default Re: B20 (CirCus)
Im not sure if this is true, but i heard the b20 swap was more if you plan on boosting it. My friend has a fully built b20 swap in his em1 and my type s eats it up by a couple cars.
Old 10-14-2007, 01:49 PM
JDMFreak's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyte-S &raquo;</TD></TR><TR><TD CLASS="quote">Im not sure if this is true, but i heard the b20 swap was more if you plan on boosting it. My friend has a fully built b20 swap in his em1 and my type s eats it up by a couple cars.</TD></TR></TABLE>
this is incorrect. the b20b does have a low compression (8.8) which any turbo kit setup would love, but the cylinder walls are prone to crack under stock boost (from what i read on H-T over a short time frame). i have not seen the inside of my b20 block yet, but it has a cast iron - 1 piece design sleeve, so it tend to crack under pressure and Heavy road course driving.
clevelee
12-03-2008 11:53 PM
nitewolf
03-28-2008 10:34 PM
DA chosen 1
05-23-2006 09:46 PM
92hatchb18
05-09-2004 06:13 PM
lsteggy
07-05-2002 03:32 AM
Quick Reply: B20
