Question for running in the rain (road course)
Old Jun 20, 2002 | 06:52 AM
Nuts's Avatar
Default Question for running in the rain (road course)
Tried in the Road racing forum, didn't get much help, so here we go.
I am preparing for the upcoming track days (road course), very excited, however, according to the weather forecast, it will be thunder showering for the whole weekend!! Now here is the question.
Tires – under wet condition, should I stick with stock RE010 or change it to RA1? Last time in the rain I ran with the RA1, I found it’s a lot less forgiving (especially when it comes to over steer, spun out twice because I counter steer too much) RE010 has 24K km on it where as the RA1 just been to the track once (lots of tread left)
TIA,
CS
Old Jun 20, 2002 | 06:59 AM
yoshi234's Avatar
I shoot brides
Default Re: Question for running in the rain (CS)
go w/ the one w/ more tread on it
yshi - who also suggests driving a little slower
Old Jun 20, 2002 | 07:06 AM
DutchITR1689's Avatar
S-03 PP!!!! Is that an option?
Old Jun 20, 2002 | 07:08 AM
Warren's Avatar
Wrong-Way Wang
RA-1's are good rain tires. Just be more careful about your inputs. You have to be smooth. Rain seperates the boys from the men.
Warren
Old Jun 20, 2002 | 07:09 AM
uNF$@#!'s Avatar
Default Re: Question for running in the rain (Warren)
tracking in the rain = awesome.
Old Jun 20, 2002 | 07:12 AM
rainman's Avatar
RA-1s all the way. Even with minimal tread depth, you will find they have greater grip than any street tire. But you must be very smooth in your driving style - this is what water on the track will teach you. Also, adjust your tire pressures for the rain, perhaps dropping a couple pounds from your typical dry set up.
Old Jun 20, 2002 | 07:13 AM
AssPenny's Avatar
Default Re: Question for running in the rain (00-0187)
Yeah I've heard it really teaches you alot. I was hoping it was going to rain the 2nd day of expo
Craig - Who does not like rain (ie see avatar )
Old Jun 20, 2002 | 09:28 AM
Big Phat R's Avatar
Stick with the RA-1s. They are much much better in the rain.
As Warren wisely said - keep your inputs smooth and drive a less aggressive line.
Also play around with tire pressures. You can probably go with lower pressures for improved traction.
Old Jun 20, 2002 | 09:47 AM
BSQ's Avatar
BSQ
Default Re: Question for running in the rain (Phat Bastard)
I would have to agree with everyones recommendation on the RA1s.
Also, you should be driving the "rain line" when it is wet. The "rain line" is the opposite of the "dry line" which you would normally drive. The "rain line" is less greasey and you will find more grip when the track is wet.
Here is a short article which talks about driving in the rain on the track: http://www.opentracking.com/rain_events.htm .
Old Jun 20, 2002 | 10:00 AM
BSQ's Avatar
BSQ
Default Re: Question for running in the rain (BSQ)
Another good article which talks about driving in the rain: http://www.proformanceraceschool.com/racenews.html
BTW, has anyone ever tried disconnecting their rear swaybar before when driving in the rain? I have always heard about real racers doing this, but I have never had a chance to try it before.
Old Jun 20, 2002 | 10:54 AM
Nuts's Avatar
Great info, thanks guys!!! as for disconnecting the rear sway bar? isn't that going to make your car alot more understeer(especially in the rain?). Why would that be beneifical for controlling the car? Cause even with the sway bar, I still find it's more likely to be understeer than oversteer in the rain.
CS
Old Jun 20, 2002 | 11:49 AM
Dave-ROR's Avatar
CS
Sounds like you're going to hot into these corners..
SnlpeR
19
Jul 30, 2006 09:11 AM
rmcdaniels
76
Jul 29, 2005 05:48 AM
Ryan126
Apr 12, 2004 09:28 AM
emwavey
Jun 19, 2003 12:22 PM
Nuts
Mar 21, 2002 02:36 PM
