Honda S2000 Honda S2000
*** CEL P0410***
Old Oct 13, 2007 | 03:33 PM
veilside_s2k's Avatar
Default *** CEL P0410***
Car runs fine with the jdm f20c. its an 01 car. 03 motor.. getting a code. P0410.
any ideas?
Old Oct 13, 2007 | 04:26 PM
papa5murf's Avatar
Default Re: *** CEL P0410*** (veilside_s2k)
The secondary air pump should be a P0410. This system injects cold air into the exhaust for 60 seconds at start-up. It is meant to improve start-up emissions efficiency. If you set a P0410 code after the initial fix reset the ECU
Old Oct 13, 2007 | 04:30 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: *** CEL P0410*** (papa5murf)
check your vac lines if everything checks out pull the bumper off and make sure its connected right its on the drivers side
Old Oct 13, 2007 | 05:21 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S@nt0s &raquo;</TD></TR><TR><TD CLASS="quote">check your vac lines if everything checks out pull the bumper off and make sure its connected right its on the drivers side</TD></TR></TABLE>
alright ill check it out
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by papa5murf &raquo;</TD></TR><TR><TD CLASS="quote">The secondary air pump should be a P0410. This system injects cold air into the exhaust for 60 seconds at start-up. It is meant to improve start-up emissions efficiency. If you set a P0410 code after the initial fix reset the ECU
alright so its nothing major and has no affect on anything besides a cleaner start up? car runs fine and starts up with ease
Old Oct 13, 2007 | 05:23 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
yes car will run fine , i did for a month n makes no effect on performance
Old Oct 13, 2007 | 06:20 PM
papa5murf's Avatar
No 'real' ill effects. More than likely it's just a loose/disconnected hose.
katyruff
Honda S2000
Jul 6, 2008 11:26 AM
MADBADGER
Honda S2000
10
Jun 27, 2008 04:57 PM
LilRedMachine
Honda S2000
Jul 19, 2006 10:51 AM
markysparky
Oct 27, 2005 06:55 PM
AKS2K
Honda S2000
18
Nov 9, 2004 10:14 PM
