Honda S2000 Honda S2000
help???
Old Jul 3, 2008 | 09:48 PM
katyruff's Avatar
Default help???
i have a few questions...
ok my mom has a 2001 s2k that the check engine light keeps coming on. our local honda dealer just keeps clearing the codes, but she would like the problem solved rather than having to clear codes all the time...
the codes that honda says its showing are
p0410 and p1410
they are telling my mom that it is an air pump system failure and air pump motor failure. as far as i know ( and i am not an expert on s2ks ) they dont have air pumps... im not even sure if the code # matches the names they have given her.
i work at a shop, and have access to scan tools, just wonderin if anyone has any input on this..
thank you!!
Old Jul 3, 2008 | 09:53 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: help??? (katyruff)
secondary pump is located behind the front bumper on the drivers side.
remove the bumper and make sure the plugs are in correctly, check your vac lines as well as they run up just in front of the motor to the valve then to the motor. so insure all your vac lines are intact and plugged in.
Old Jul 5, 2008 | 04:32 PM
Joro Corona's Avatar
I had this for abit, apparently a bird had gotten... we slaughtered by my car, and the pump wiring got chopped up by the carnage. Couple of butt connectors and all was well in the world.
Old Jul 5, 2008 | 06:01 PM
Techno Tonis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by katyruff &raquo;</TD></TR><TR><TD CLASS="quote">i have a few questions...
p0410 and p1410
thank you!!
Air pump is only useful for e-check. No worries.
Old Jul 5, 2008 | 10:08 PM
Black S2K's Avatar
check all the vac lines and make sure the solinoide is working. This code will not hinder the performence of the car nore is it hurting the car. The secondery air injection system is only for emissions purposes
Old Jul 6, 2008 | 10:08 AM
Agent Zero's Avatar
Default Re: (Black S2K)
Depending on were you live most states wont let the car pass inspection with a CEL. Sounds shady the dealer wont fix it or tell you how to fix it. Good luck dude.
Old Jul 6, 2008 | 11:26 AM
RNPoo7's Avatar
Default Re: (Agent Zero)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Agent Zero &raquo;</TD></TR><TR><TD CLASS="quote">Depending on were you live most states wont let the car pass inspection with a CEL. Sounds shady the dealer wont fix it or tell you how to fix it. Good luck dude. </TD></TR></TABLE>
I was thinking the same. Take it to a different Honda dealership.
veilside_s2k
Honda S2000
Oct 13, 2007 06:20 PM
regimeteam
Honda S2000
Apr 23, 2007 05:12 PM
sounguy787
Honda S2000
Oct 12, 2006 12:40 PM
B18CXr
Honda S2000
Jun 9, 2005 08:45 AM
AKS2K
Honda S2000
18
Nov 9, 2004 10:14 PM
